2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2017-08-25 | cpu-supplement: Use literal instead of emphasis | Sebastian Huber | 1 | -10/+11 | |
Update #3082. | |||||
2017-08-24 | cpu-supplement: Fix PowerPC TOC limitation | Sebastian Huber | 1 | -2/+3 | |
2017-08-23 | cpu-supplement/powerpc: Rewrite | Sebastian Huber | 1 | -475/+38 | |
Remove obsolete and duplicated information. Reference the ABI specifications. Add 64-bit caveats. Update #3082. | |||||
2016-11-10 | cpu-supplement: Document PowerPC SPRG0-2 usage | Sebastian Huber | 1 | -0/+11 | |
2016-11-09 | cpu-supplement: Fix header levels. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | cpu_supplement: Fixed numbered list | Joel Sherrill | 1 | -24/+24 | |
2016-10-28 | powerpc, sparc, sparc64: Correct tables | Joel Sherrill | 1 | -8/+8 | |
2016-10-07 | Clean up the CPU Supplement. | Chris Johns | 1 | -298/+258 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -15/+15 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+607 | |
