path: root/cpu-supplement/openrisc_1000.rst (unfollow)
2019-02-08Add copyright noticesSebastian Huber1-0/+1
2019-01-11Simplify SPDX-License-Identifier commentSebastian Huber1-1/+1
2019-01-11Remove superfluous "All rights reserved."Sebastian Huber1-1/+0
2019-01-11Use standard format for copyright linesSebastian Huber1-2/+1
2016-11-09cpu-supplement: Fix header levels.Chris Johns1-1/+1
2016-11-03Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns1-0/+0
2016-10-07Clean up the CPU Supplement.Chris Johns1-19/+18
2016-05-20Set SPDX License Identifier in each source file.Chris Johns1-0/+2
2016-05-02Split document into seperate files by section.Amar Takhar1-0/+96
