2019-02-08 | Add copyright notices | Sebastian Huber | 1 | -0/+1 | |
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2016-11-09 | cpu-supplement: Fix header levels. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-07 | Clean up the CPU Supplement. | Chris Johns | 1 | -19/+18 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+96 | |
