path: root/cpu-supplement/index.rst (follow)
* Update the copyright year.Chris Johns2018-10-191-1/+1
* build: Fix indexing so it works on HTML and PDF.Chris Johns2018-08-211-0/+2
| | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503
* cpu-supplement: Remove empty indexSebastian Huber2018-08-201-2/+0
| | | | | | | | Due to the hierarchical structure an index is not absolutely necessary and an empty index is not helpful. The document sources contain no index directives. Close #3499.
* cpu-supplement: Remove empty command/vars chapterSebastian Huber2018-08-201-1/+0
| | | | Close #3498.
* cpu-supplement: Add RISC-V chapterSebastian Huber2018-08-021-0/+1
| | | | Update #3433.
* Add indexes to all documents.Chris Johns2017-11-121-2/+1
| | | | Update #3229.
* Update copyright notices.Chris Johns2017-08-111-4/+7
* c-user: Add support for references via bibtexSebastian Huber2017-01-181-0/+1
| | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871.
* Update document titles for consistencyJoel Sherrill2017-01-111-3/+3
* cpu-supplement: Fix header levels.Chris Johns2016-11-091-1/+4
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+59
