2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 3 | -17/+48 | |
2016-05-02 | Add .svg logos for RTEMS that I made myself. | Amar Takhar | 2 | -0/+459 | |
One is plain SVG the other has the Inkscape metadata in it. | |||||
2016-05-02 | Add logo.pdf for PDF documents. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 4 | -2/+53 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 3 | -21/+51 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Fix rtemsconfig building. | Amar Takhar | 1 | -0/+2 | |
I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. |
