* | html: Update the CSS and add topics. | Chris Johns | 2016-11-02 | 1 | -8/+30 |
* | waf: Fix the sphinx verbose option. | Chris Johns | 2016-11-02 | 1 | -2/+8 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 1 | -43/+67 |
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 1 | -16/+44 |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 |
* | waf: Update to support a recent waf. | Chris Johns | 2016-10-29 | 1 | -2/+2 |
* | common/waf.py: Improve Sphinx version parsing to work with their git master | Joel Sherrill | 2016-10-27 | 1 | -2/+2 |
* | waf: Fix for waf-1.9.3. | Chris Johns | 2016-09-09 | 1 | -1/+1 |
* | Make the Warning colours match the theme. | Chris Johns | 2016-07-04 | 1 | -0/+12 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 1 | -4/+16 |
* | Updates from user reviews. | Chris Johns | 2016-05-02 | 1 | -0/+1 |
* | Remove the minted gobble. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 2016-05-02 | 3 | -1/+11 |
* | Add Minted 2015/12/21 v2.2dev (ce7a111) | Amar Takhar | 2016-05-02 | 1 | -0/+1513 |
* | Better error message, add FTP to the URL list. | Chris Johns | 2016-05-02 | 1 | -1/+2 |
* | Format the index for PDF output. | Chris Johns | 2016-05-02 | 1 | -0/+4 |
* | Run through 2to3. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Wrap \tabulary environment to allow breaking underscores. | Amar Takhar | 2016-05-02 | 1 | -0/+9 |
| | | | | * This \discretionary to avoid language issues. | ||||
* | Add wrap support to long table entries. | Chris Johns | 2016-05-02 | 1 | -20/+14 |
* | Add an rtems-table class to wrap and align HTML tables. | Chris Johns | 2016-05-02 | 1 | -0/+32 |
* | Fix PDF layout. | Chris Johns | 2016-05-02 | 2 | -2/+4 |
* | Add my-style.css support and add RTEMS to that CSS. | Chris Johns | 2016-05-02 | 4 | -3/+116 |
* | Generate a fatal error on a Sphinx beta version that cannot be parsed. | Chris Johns | 2016-05-02 | 1 | -3/+5 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+15 |
* | Remove incorrect pdflatex/makeindex check. | Amar Takhar | 2016-05-02 | 1 | -4/+0 |
* | Only require makeindex and pdflatex when trying to build PDF. | Amar Takhar | 2016-05-02 | 1 | -3/+3 |
* | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 2016-05-02 | 30 | -92/+79 |
| | | | | | | | | | * This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | ||||
* | Fix typo and add another dependency. | Amar Takhar | 2016-05-02 | 1 | -2/+2 |
* | Add minimum version check for Sphinx. | Amar Takhar | 2016-05-02 | 1 | -1/+24 |
| | | | | Some distributions have ancient versions we require at least 1.3. | ||||
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 3 | -17/+48 |
* | Add .svg logos for RTEMS that I made myself. | Amar Takhar | 2016-05-02 | 2 | -0/+459 |
| | | | | One is plain SVG the other has the Inkscape metadata in it. | ||||
* | Add logo.pdf for PDF documents. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 4 | -2/+53 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 3 | -21/+51 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Fix rtemsconfig building. | Amar Takhar | 2016-05-02 | 1 | -0/+2 |
| | | | | | I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. | ||||
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 37 | -0/+1939 |
