* | common: Enable numfig role | Sebastian Huber | 2020-09-13 | 1 | -0/+3 |
* | common: Fix pale color of HTML definition terms | Sebastian Huber | 2020-08-07 | 1 | -1/+0 |
* | common: Remove probably superfluous import | Sebastian Huber | 2020-07-08 | 1 | -1/+0 |
| | | | | | | | | | The purpose of this import is unclear. This import caused the following error with Sphinx 3.0: Extension error: Could not import extension rtemsdomain (exception: cannot import name 'l_') | ||||
* | common: fix title page | Gedare Bloom | 2020-04-04 | 2 | -1/+2 |
| | | | | | Sphinx changed the default behavior of maketitle. Provide our own rtemsmaketitle command and use it instead. | ||||
* | waf: User friendly message when no sphinx is installed | Chris Johns | 2020-04-03 | 1 | -0/+3 |
* | waf: Get the version numbers from the version file. | Chris Johns | 2020-03-13 | 3 | -5/+40 |
* | sphinx: Add a custom highlight colour | Chris Johns | 2020-03-13 | 1 | -0/+5 |
| | | | | Update #2998 | ||||
* | Update sphinx_rtd_theme to https://github.com/readthedocs/sphinx_rtd_theme/ | Amar Takhar | 2020-02-26 | 55 | -1039/+3679 |
| | | | | | | | | | 68a19ca / 0.4.3.dev0. I have been using this one for a while without issues. This should fix the search issues. closes #3880 | ||||
* | Revert "common: Add URLs to manuals" | Sebastian Huber | 2020-02-04 | 1 | -13/+1 |
| | | | | | This reverts commit 1fdd3cf83d154af66ad0edf5094d93075063c7e0 and some follow up changes. | ||||
* | common: Add URLs to manuals | Sebastian Huber | 2020-01-07 | 1 | -1/+13 |
* | waf/common: Fix UTF-8 encoding of HTML inliner output on Python3. | Chris Johns | 2019-10-29 | 1 | -5/+13 |
* | common: Show page references after internal links | Sebastian Huber | 2019-08-14 | 2 | -59/+1 |
| | | | | | | | The custom RTEMS extension produced quite verbose references like "Chapter 3 - Section 7 - Bla blub". This may distract the reading flow. Use a standard Sphinx option to show page references instead, e.g. "Bla blub (page 11)". This has some value for printed out documents. | ||||
* | common: Align "Build Logs" with other list names | Sebastian Huber | 2019-08-05 | 1 | -1/+1 |
* | refs: Update EARS references | Sebastian Huber | 2019-07-24 | 1 | -2/+20 |
* | refs: Add ECSS standard references | Sebastian Huber | 2019-07-23 | 1 | -0/+51 |
| | | | | | Add the ECSS standards in a separate block. Use a custom label scheme to make citations easier. | ||||
* | refs: Replace non-ASCII character | Sebastian Huber | 2019-07-23 | 1 | -1/+1 |
* | common: Add references | Sebastian Huber | 2019-07-11 | 1 | -0/+49 |
* | c-user: Add RTEID and ORKID references | Sebastian Huber | 2019-06-21 | 1 | -0/+18 |
* | waf: Fix argument bug getting extra source. | Chris Johns | 2019-03-01 | 1 | -1/+1 |
* | waf: Add support for extra and excluded sources. | Chris Johns | 2019-02-28 | 1 | -14/+32 |
* | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 2019-02-28 | 1 | -13/+28 |
| | | | | | Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | ||||
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -0/+5 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | waf: Fix building the images in the src path. | Chris Johns | 2019-02-28 | 1 | -2/+1 |
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -1/+1 |
* | common/latex.py: Remove hack for CentOS. Use Texlive per instructions. | Joel Sherrill | 2019-02-13 | 1 | -8/+0 |
* | waf: Use the release date in the coverpage | Chris Johns | 2019-02-14 | 1 | -2/+2 |
* | waf: Fix version.py to support older versions of git. | Chris Johns | 2019-02-13 | 1 | -17/+34 |
* | Remove minted from the PDF builds. | Chris Johns | 2019-02-13 | 3 | -1518/+2 |
| | | | | | | This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | ||||
* | Fix the version logic to make it more robust. | Chris Johns | 2019-02-07 | 1 | -1/+4 |
* | Fix building with Sphinx 1.8 and later. | Chris Johns | 2019-02-06 | 2 | -14/+33 |
| | | | | | | | | - Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | ||||
* | Support VERSION file for releasing and deployment | Chris Johns | 2019-02-06 | 1 | -0/+150 |
| | | | | - Shorten the GIT hash. | ||||
* | Change first copyright year to 1988 | Sebastian Huber | 2019-01-18 | 1 | -1/+1 |
| | | | | The OAR copyright goes back to 1988. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -0/+6 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | common/header: Add missing copyright notice | Sebastian Huber | 2019-01-11 | 1 | -0/+4 |
* | Update header.rst | Sebastian Huber | 2019-01-09 | 1 | -10/+10 |
| | | | | Remove trailing slashes in URLs. Fix bug reporting URL. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -0/+23 |
* | Remove superfluous word "Copyright" | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | The © symbol is sufficient. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 2 | -44/+3 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | common/waf.py: Fix indentation. | Christian Mauderer | 2018-12-18 | 1 | -1/+1 |
| | | | | Python 3 produces an error if indentation is mixed tabs and spaces. | ||||
* | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 2018-12-05 | 1 | -2/+2 |
| | | | | | | | | | | This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | ||||
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 1 | -1/+69 |
* | Add a README file containing the colours used in the RTEMS logo. | Amar Takhar | 2018-10-24 | 1 | -0/+5 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | waf: Fix type in single html build. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
* | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2018-08-21 | 2 | -1/+4 |
| | | | | | I removed the '_' splitting of long labels from the index when testing and this puts it back. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 5 | -43/+57 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 2 | -5/+23 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | build: Add extra source to the sphinx build. | Chris Johns | 2017-10-12 | 1 | -11/+11 |
| | | | | Updates #3177. | ||||
* | Improve the line spaces for directives and notes. | Chris Johns | 2017-09-14 | 1 | -7/+20 |
