2019-08-05 | common: Align "Build Logs" with other list names | Sebastian Huber | 1 | -1/+1 | |
2019-07-24 | refs: Update EARS references | Sebastian Huber | 1 | -2/+20 | |
2019-07-23 | refs: Add ECSS standard references | Sebastian Huber | 1 | -0/+51 | |
Add the ECSS standards in a separate block. Use a custom label scheme to make citations easier. | |||||
2019-07-23 | refs: Replace non-ASCII character | Sebastian Huber | 1 | -1/+1 | |
2019-07-11 | common: Add references | Sebastian Huber | 1 | -0/+49 | |
2019-06-21 | c-user: Add RTEID and ORKID references | Sebastian Huber | 1 | -0/+18 | |
2019-03-01 | waf: Fix argument bug getting extra source. | Chris Johns | 1 | -1/+1 | |
2019-02-28 | waf: Add support for extra and excluded sources. | Chris Johns | 1 | -14/+32 | |
2019-02-28 | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 1 | -13/+28 | |
Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | |||||
2019-02-28 | Add unicode support for commonly used characters like copyright. | Chris Johns | 1 | -0/+5 | |
- This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | |||||
2019-02-28 | waf: Fix building the images in the src path. | Chris Johns | 1 | -2/+1 | |
2019-02-15 | Use pathto() on the genindex URL to make it relative. | Chris Johns | 1 | -1/+1 | |
2019-02-13 | common/latex.py: Remove hack for CentOS. Use Texlive per instructions. | Joel Sherrill | 1 | -8/+0 | |
2019-02-14 | waf: Use the release date in the coverpage | Chris Johns | 1 | -2/+2 | |
2019-02-13 | waf: Fix version.py to support older versions of git. | Chris Johns | 1 | -17/+34 | |
2019-02-13 | Remove minted from the PDF builds. | Chris Johns | 3 | -1518/+2 | |
This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | |||||
2019-02-07 | Fix the version logic to make it more robust. | Chris Johns | 1 | -1/+4 | |
2019-02-06 | Fix building with Sphinx 1.8 and later. | Chris Johns | 2 | -14/+33 | |
- Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | |||||
2019-02-06 | Support VERSION file for releasing and deployment | Chris Johns | 1 | -0/+150 | |
- Shorten the GIT hash. | |||||
2019-01-18 | Change first copyright year to 1988 | Sebastian Huber | 1 | -1/+1 | |
The OAR copyright goes back to 1988. | |||||
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -0/+6 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | common/header: Add missing copyright notice | Sebastian Huber | 1 | -0/+4 | |
2019-01-09 | Update header.rst | Sebastian Huber | 1 | -10/+10 | |
Remove trailing slashes in URLs. Fix bug reporting URL. | |||||
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -0/+23 | |
2019-01-09 | Remove superfluous word "Copyright" | Sebastian Huber | 1 | -1/+1 | |
The © symbol is sufficient. | |||||
2019-01-09 | Update general copyright notice | Sebastian Huber | 1 | -1/+1 | |
Update year and add "and contributors". | |||||
2019-01-09 | Replace build date with Git hash and commit date | Sebastian Huber | 2 | -44/+3 | |
The usage of a build date prevents reproducible builds. | |||||
2018-12-18 | common/waf.py: Fix indentation. | Christian Mauderer | 1 | -1/+1 | |
Python 3 produces an error if indentation is mixed tabs and spaces. | |||||
2018-12-05 | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 1 | -2/+2 | |
This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | |||||
2018-11-03 | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 1 | -1/+69 | |
2018-10-24 | Add a README file containing the colours used in the RTEMS logo. | Amar Takhar | 1 | -0/+5 | |
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | waf: Fix type in single html build. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2 | -1/+4 | |
I removed the '_' splitting of long labels from the index when testing and this puts it back. | |||||
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 5 | -43/+57 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-03-09 | RTEMS Docs: Check sphinx version | Richard Campbell | 2 | -5/+23 | |
Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | |||||
2017-10-12 | build: Add extra source to the sphinx build. | Chris Johns | 1 | -11/+11 | |
Updates #3177. | |||||
2017-09-14 | Improve the line spaces for directives and notes. | Chris Johns | 1 | -7/+20 | |
2017-08-25 | common: Remove obsolete latex_use_parts | Sebastian Huber | 1 | -4/+0 | |
This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | |||||
2017-08-11 | coverpage: Fix repeated entries. | Chris Johns | 1 | -2/+2 | |
Closes #2865. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -2/+2 | |
2017-08-11 | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 1 | -54/+23 | |
2017-08-11 | common/conf: Clean up. | Chris Johns | 1 | -4/+0 | |
2017-08-09 | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 8 | -975/+1 | |
This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | |||||
2017-08-07 | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 8 | -1/+975 | |
2017-03-27 | Add Windows build details. | Chris Johns | 1 | -1/+1 | |
Actually include the quoting fix for Windows. | |||||
2017-03-27 | waf: Fix linkcheck and spell commands. | Chris Johns | 1 | -45/+19 | |
Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | |||||
2017-03-21 | conf: Update the copyright year. | Chris Johns | 1 | -2/+7 | |
2017-03-21 | waf: Create the sphinx rule in one place. | Chris Johns | 1 | -11/+11 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 2 | -14/+35 | |
