2018-03-09 | RTEMS Docs: Check sphinx version | Richard Campbell | 2 | -5/+23 | |
Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | |||||
2017-10-12 | build: Add extra source to the sphinx build. | Chris Johns | 1 | -11/+11 | |
Updates #3177. | |||||
2017-09-14 | Improve the line spaces for directives and notes. | Chris Johns | 1 | -7/+20 | |
2017-08-25 | common: Remove obsolete latex_use_parts | Sebastian Huber | 1 | -4/+0 | |
This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | |||||
2017-08-11 | coverpage: Fix repeated entries. | Chris Johns | 1 | -2/+2 | |
Closes #2865. | |||||
2017-08-11 | Update copyright notices. | Chris Johns | 1 | -2/+2 | |
2017-08-11 | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 1 | -54/+23 | |
2017-08-11 | common/conf: Clean up. | Chris Johns | 1 | -4/+0 | |
2017-08-09 | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 8 | -975/+1 | |
This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | |||||
2017-08-07 | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 8 | -1/+975 | |
2017-03-27 | Add Windows build details. | Chris Johns | 1 | -1/+1 | |
Actually include the quoting fix for Windows. | |||||
2017-03-27 | waf: Fix linkcheck and spell commands. | Chris Johns | 1 | -45/+19 | |
Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | |||||
2017-03-21 | conf: Update the copyright year. | Chris Johns | 1 | -2/+7 | |
2017-03-21 | waf: Create the sphinx rule in one place. | Chris Johns | 1 | -11/+11 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 2 | -14/+35 | |
2017-03-15 | user: Add tool commands to the user manual. | Chris Johns | 1 | -0/+9 | |
2017-03-15 | waf: Configure check the inliner only once. | Chris Johns | 1 | -5/+7 | |
2017-02-25 | Add a check for Sphinx extensions. | Chris Johns | 1 | -15/+44 | |
Minor clean up of the configure messages. Do not re-check sphinx in the nested configures. | |||||
2017-02-22 | Move extensions to common conf.py | Sebastian Huber | 1 | -1/+2 | |
2017-02-02 | c-user: Add SMP application issues section | Sebastian Huber | 1 | -0/+4 | |
2017-02-02 | c-user: Update clustered scheduling | Sebastian Huber | 1 | -7/+34 | |
2017-02-01 | Do not show page references after internal links | Sebastian Huber | 1 | -1/+1 | |
2017-02-01 | Fix refs.bib entries | Sebastian Huber | 1 | -1/+2 | |
2017-02-01 | c-user: Add Key concept locking protocols | Sebastian Huber | 1 | -0/+16 | |
Update #2412. Update #2556. | |||||
2017-01-31 | Fix refs.bib entry | Sebastian Huber | 1 | -1/+2 | |
2017-01-30 | c-user: Add timer and timeouts key concept | Sebastian Huber | 1 | -0/+1 | |
Update #2554. | |||||
2017-01-30 | refs.bib: Add URL | Sebastian Huber | 1 | -0/+1 | |
2017-01-30 | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 1 | -1/+66 | |
State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | |||||
2017-01-25 | Fix some reference titles | Sebastian Huber | 1 | -3/+3 | |
2017-01-25 | Sort references | Sebastian Huber | 1 | -108/+110 | |
2017-01-18 | c-user: Add support for references via bibtex | Sebastian Huber | 1 | -0/+173 | |
https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
2017-01-12 | coverpage: Remove used function. | Chris Johns | 1 | -15/+0 | |
2017-01-12 | coverpage: Make showing the table conditional. | Chris Johns | 2 | -5/+5 | |
2017-01-12 | coverpage: Rename the static images directory to match bootstrap. | Chris Johns | 3 | -2/+2 | |
2017-01-12 | coverpage: Fix the catalogue table id. | Chris Johns | 1 | -1/+2 | |
2017-01-12 | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 13 | -16/+47 | |
Add each doc's conf.py as a dependence to catalogue.xml. | |||||
2017-01-11 | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 1 | -1/+7 | |
2017-01-11 | html: Embed the catalogue XML in JS. | Chris Johns | 3 | -40/+57 | |
The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | |||||
2017-01-11 | html: Add support for an HTML cover page for releases. | Chris Johns | 10 | -0/+268 | |
2017-01-10 | waf: Add a title to the XML Catalogue. | Chris Johns | 1 | -1/+6 | |
2017-01-10 | waf: Improved XML Catalogue generator. | Chris Johns | 1 | -44/+41 | |
2017-01-09 | waf: Create an XML Catalogue. | Chris Johns | 1 | -0/+78 | |
2016-11-09 | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2 | -2/+6 | |
build PDF. | |||||
2016-11-09 | latex: Increase the depth of subsections. | Chris Johns | 1 | -4/+7 | |
2016-11-08 | waf: Get a copy of the optional packages. | Chris Johns | 1 | -2/+2 | |
2016-11-08 | waf: Use the good fonts if installed. | Chris Johns | 5 | -22/+49 | |
2016-11-08 | pdf: Format lists for directives to sit on the next line. | Chris Johns | 3 | -2/+7 | |
2016-11-07 | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 4 | -146/+5 | |
2016-11-07 | waf: Add a program test for pygmentize. | Chris Johns | 1 | -0/+3 | |
2016-11-07 | waf: Fix ''NoneType' object is not iterable' | Christian Mauderer | 1 | -4/+6 | |
