* | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 2018-12-05 | 1 | -2/+2 |
| | | | | | | | | | | This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | ||||
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 1 | -1/+69 |
* | Add a README file containing the colours used in the RTEMS logo. | Amar Takhar | 2018-10-24 | 1 | -0/+5 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | waf: Fix type in single html build. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
* | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2018-08-21 | 2 | -1/+4 |
| | | | | | I removed the '_' splitting of long labels from the index when testing and this puts it back. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 5 | -43/+57 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 2 | -5/+23 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | build: Add extra source to the sphinx build. | Chris Johns | 2017-10-12 | 1 | -11/+11 |
| | | | | Updates #3177. | ||||
* | Improve the line spaces for directives and notes. | Chris Johns | 2017-09-14 | 1 | -7/+20 |
* | common: Remove obsolete latex_use_parts | Sebastian Huber | 2017-08-25 | 1 | -4/+0 |
| | | | | | | | | This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | ||||
* | coverpage: Fix repeated entries. | Chris Johns | 2017-08-11 | 1 | -2/+2 |
| | | | | Closes #2865. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -2/+2 |
* | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 2017-08-11 | 1 | -54/+23 |
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 2017-08-09 | 8 | -975/+1 |
| | | | | | | This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | ||||
* | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 2017-08-07 | 8 | -1/+975 |
* | Add Windows build details. | Chris Johns | 2017-03-27 | 1 | -1/+1 |
| | | | | Actually include the quoting fix for Windows. | ||||
* | waf: Fix linkcheck and spell commands. | Chris Johns | 2017-03-27 | 1 | -45/+19 |
| | | | | | | Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | ||||
* | conf: Update the copyright year. | Chris Johns | 2017-03-21 | 1 | -2/+7 |
* | waf: Create the sphinx rule in one place. | Chris Johns | 2017-03-21 | 1 | -11/+11 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 2 | -14/+35 |
* | user: Add tool commands to the user manual. | Chris Johns | 2017-03-15 | 1 | -0/+9 |
* | waf: Configure check the inliner only once. | Chris Johns | 2017-03-15 | 1 | -5/+7 |
* | Add a check for Sphinx extensions. | Chris Johns | 2017-02-25 | 1 | -15/+44 |
| | | | | | | Minor clean up of the configure messages. Do not re-check sphinx in the nested configures. | ||||
* | Move extensions to common conf.py | Sebastian Huber | 2017-02-22 | 1 | -1/+2 |
* | c-user: Add SMP application issues section | Sebastian Huber | 2017-02-02 | 1 | -0/+4 |
* | c-user: Update clustered scheduling | Sebastian Huber | 2017-02-02 | 1 | -7/+34 |
* | Do not show page references after internal links | Sebastian Huber | 2017-02-01 | 1 | -1/+1 |
* | Fix refs.bib entries | Sebastian Huber | 2017-02-01 | 1 | -1/+2 |
* | c-user: Add Key concept locking protocols | Sebastian Huber | 2017-02-01 | 1 | -0/+16 |
| | | | | | Update #2412. Update #2556. | ||||
* | Fix refs.bib entry | Sebastian Huber | 2017-01-31 | 1 | -1/+2 |
* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
| | | | | Update #2554. | ||||
* | refs.bib: Add URL | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
* | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 2017-01-30 | 1 | -1/+66 |
| | | | | | | | | | State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | ||||
* | Fix some reference titles | Sebastian Huber | 2017-01-25 | 1 | -3/+3 |
* | Sort references | Sebastian Huber | 2017-01-25 | 1 | -108/+110 |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 1 | -0/+173 |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | ||||
* | coverpage: Remove used function. | Chris Johns | 2017-01-12 | 1 | -15/+0 |
* | coverpage: Make showing the table conditional. | Chris Johns | 2017-01-12 | 2 | -5/+5 |
* | coverpage: Rename the static images directory to match bootstrap. | Chris Johns | 2017-01-12 | 3 | -2/+2 |
* | coverpage: Fix the catalogue table id. | Chris Johns | 2017-01-12 | 1 | -1/+2 |
* | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 2017-01-12 | 13 | -16/+47 |
| | | | | Add each doc's conf.py as a dependence to catalogue.xml. | ||||
* | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 2017-01-11 | 1 | -1/+7 |
* | html: Embed the catalogue XML in JS. | Chris Johns | 2017-01-11 | 3 | -40/+57 |
| | | | | | The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | ||||
* | html: Add support for an HTML cover page for releases. | Chris Johns | 2017-01-11 | 10 | -0/+268 |
* | waf: Add a title to the XML Catalogue. | Chris Johns | 2017-01-10 | 1 | -1/+6 |
* | waf: Improved XML Catalogue generator. | Chris Johns | 2017-01-10 | 1 | -44/+41 |
* | waf: Create an XML Catalogue. | Chris Johns | 2017-01-09 | 1 | -0/+78 |
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 2 | -2/+6 |
| | | | | build PDF. |
