* | common: Align "Build Logs" with other list names | Sebastian Huber | 2019-08-05 | 1 | -1/+1 |
* | refs: Update EARS references | Sebastian Huber | 2019-07-24 | 1 | -2/+20 |
* | refs: Add ECSS standard references | Sebastian Huber | 2019-07-23 | 1 | -0/+51 |
| | | | | | Add the ECSS standards in a separate block. Use a custom label scheme to make citations easier. | ||||
* | refs: Replace non-ASCII character | Sebastian Huber | 2019-07-23 | 1 | -1/+1 |
* | common: Add references | Sebastian Huber | 2019-07-11 | 1 | -0/+49 |
* | c-user: Add RTEID and ORKID references | Sebastian Huber | 2019-06-21 | 1 | -0/+18 |
* | waf: Fix argument bug getting extra source. | Chris Johns | 2019-03-01 | 1 | -1/+1 |
* | waf: Add support for extra and excluded sources. | Chris Johns | 2019-02-28 | 1 | -14/+32 |
* | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 2019-02-28 | 1 | -13/+28 |
| | | | | | Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | ||||
* | Add unicode support for commonly used characters like copyright. | Chris Johns | 2019-02-28 | 1 | -0/+5 |
| | | | | | - This change makes the copyright character easier to see on editors lacking good unicode rendering support, ie terminals. | ||||
* | waf: Fix building the images in the src path. | Chris Johns | 2019-02-28 | 1 | -2/+1 |
* | Use pathto() on the genindex URL to make it relative. | Chris Johns | 2019-02-15 | 1 | -1/+1 |
* | common/latex.py: Remove hack for CentOS. Use Texlive per instructions. | Joel Sherrill | 2019-02-13 | 1 | -8/+0 |
* | waf: Use the release date in the coverpage | Chris Johns | 2019-02-14 | 1 | -2/+2 |
* | waf: Fix version.py to support older versions of git. | Chris Johns | 2019-02-13 | 1 | -17/+34 |
* | Remove minted from the PDF builds. | Chris Johns | 2019-02-13 | 3 | -1518/+2 |
| | | | | | | This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | ||||
* | Fix the version logic to make it more robust. | Chris Johns | 2019-02-07 | 1 | -1/+4 |
* | Fix building with Sphinx 1.8 and later. | Chris Johns | 2019-02-06 | 2 | -14/+33 |
| | | | | | | | | - Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | ||||
* | Support VERSION file for releasing and deployment | Chris Johns | 2019-02-06 | 1 | -0/+150 |
| | | | | - Shorten the GIT hash. | ||||
* | Change first copyright year to 1988 | Sebastian Huber | 2019-01-18 | 1 | -1/+1 |
| | | | | The OAR copyright goes back to 1988. | ||||
* | Reformat and update copyright and license notices | Sebastian Huber | 2019-01-14 | 1 | -0/+6 |
| | | | | | | | | For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | ||||
* | common/header: Add missing copyright notice | Sebastian Huber | 2019-01-11 | 1 | -0/+4 |
* | Update header.rst | Sebastian Huber | 2019-01-09 | 1 | -10/+10 |
| | | | | Remove trailing slashes in URLs. Fix bug reporting URL. | ||||
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -0/+23 |
* | Remove superfluous word "Copyright" | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | The © symbol is sufficient. | ||||
* | Update general copyright notice | Sebastian Huber | 2019-01-09 | 1 | -1/+1 |
| | | | | Update year and add "and contributors". | ||||
* | Replace build date with Git hash and commit date | Sebastian Huber | 2019-01-09 | 2 | -44/+3 |
| | | | | The usage of a build date prevents reproducible builds. | ||||
* | common/waf.py: Fix indentation. | Christian Mauderer | 2018-12-18 | 1 | -1/+1 |
| | | | | Python 3 produces an error if indentation is mixed tabs and spaces. | ||||
* | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 2018-12-05 | 1 | -2/+2 |
| | | | | | | | | | | This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | ||||
* | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 2018-11-03 | 1 | -1/+69 |
* | Add a README file containing the colours used in the RTEMS logo. | Amar Takhar | 2018-10-24 | 1 | -0/+5 |
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | waf: Fix type in single html build. | Chris Johns | 2018-08-21 | 1 | -1/+1 |
* | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 2018-08-21 | 2 | -1/+4 |
| | | | | | I removed the '_' splitting of long labels from the index when testing and this puts it back. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 5 | -43/+57 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 2 | -5/+23 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | build: Add extra source to the sphinx build. | Chris Johns | 2017-10-12 | 1 | -11/+11 |
| | | | | Updates #3177. | ||||
* | Improve the line spaces for directives and notes. | Chris Johns | 2017-09-14 | 1 | -7/+20 |
* | common: Remove obsolete latex_use_parts | Sebastian Huber | 2017-08-25 | 1 | -4/+0 |
| | | | | | | | | This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | ||||
* | coverpage: Fix repeated entries. | Chris Johns | 2017-08-11 | 1 | -2/+2 |
| | | | | Closes #2865. | ||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -2/+2 |
* | pdf: Update the RTEMS style to work recent Sphinx versions. | Chris Johns | 2017-08-11 | 1 | -54/+23 |
* | common/conf: Clean up. | Chris Johns | 2017-08-11 | 1 | -4/+0 |
* | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 2017-08-09 | 8 | -975/+1 |
| | | | | | | This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | ||||
* | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 2017-08-07 | 8 | -1/+975 |
* | Add Windows build details. | Chris Johns | 2017-03-27 | 1 | -1/+1 |
| | | | | Actually include the quoting fix for Windows. | ||||
* | waf: Fix linkcheck and spell commands. | Chris Johns | 2017-03-27 | 1 | -45/+19 |
| | | | | | | Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | ||||
* | conf: Update the copyright year. | Chris Johns | 2017-03-21 | 1 | -2/+7 |
* | waf: Create the sphinx rule in one place. | Chris Johns | 2017-03-21 | 1 | -11/+11 |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 2 | -14/+35 |
