* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
| | | | | Update #2554. | ||||
* | refs.bib: Add URL | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
* | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 2017-01-30 | 1 | -1/+66 |
| | | | | | | | | | State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | ||||
* | Fix some reference titles | Sebastian Huber | 2017-01-25 | 1 | -3/+3 |
* | Sort references | Sebastian Huber | 2017-01-25 | 1 | -108/+110 |
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 1 | -0/+173 |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | ||||
* | coverpage: Remove used function. | Chris Johns | 2017-01-12 | 1 | -15/+0 |
* | coverpage: Make showing the table conditional. | Chris Johns | 2017-01-12 | 2 | -5/+5 |
* | coverpage: Rename the static images directory to match bootstrap. | Chris Johns | 2017-01-12 | 3 | -2/+2 |
* | coverpage: Fix the catalogue table id. | Chris Johns | 2017-01-12 | 1 | -1/+2 |
* | coverpage: Update the coverpage to have the table collapse. | Chris Johns | 2017-01-12 | 13 | -16/+47 |
| | | | | Add each doc's conf.py as a dependence to catalogue.xml. | ||||
* | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 2017-01-11 | 1 | -1/+7 |
* | html: Embed the catalogue XML in JS. | Chris Johns | 2017-01-11 | 3 | -40/+57 |
| | | | | | The is to work around a security issue with Chrome on Windows. This patches let the cover page load on Chrome and Edge on Windows 10. | ||||
* | html: Add support for an HTML cover page for releases. | Chris Johns | 2017-01-11 | 10 | -0/+268 |
* | waf: Add a title to the XML Catalogue. | Chris Johns | 2017-01-10 | 1 | -1/+6 |
* | waf: Improved XML Catalogue generator. | Chris Johns | 2017-01-10 | 1 | -44/+41 |
* | waf: Create an XML Catalogue. | Chris Johns | 2017-01-09 | 1 | -0/+78 |
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 2 | -2/+6 |
| | | | | build PDF. | ||||
* | latex: Increase the depth of subsections. | Chris Johns | 2016-11-09 | 1 | -4/+7 |
* | waf: Get a copy of the optional packages. | Chris Johns | 2016-11-08 | 1 | -2/+2 |
* | waf: Use the good fonts if installed. | Chris Johns | 2016-11-08 | 5 | -22/+49 |
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 3 | -2/+7 |
* | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 2016-11-07 | 4 | -146/+5 |
* | waf: Add a program test for pygmentize. | Chris Johns | 2016-11-07 | 1 | -0/+3 |
* | waf: Fix ''NoneType' object is not iterable' | Christian Mauderer | 2016-11-07 | 1 | -4/+6 |
* | waf: Fix the host version check. | Chris Johns | 2016-11-06 | 1 | -3/+3 |
* | waf: Add support to handle missing Latex packages on hosts they are not ↵ | Chris Johns | 2016-11-06 | 11 | -95/+1113 |
| | | | | | | | | | | available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font. | ||||
* | waf: Check for texlive packages and report an error is not found. | Chris Johns | 2016-11-04 | 1 | -6/+106 |
* | waf: Fix the bnode issue when building in a manual directory. | Chris Johns | 2016-11-04 | 1 | -1/+1 |
* | waf: Use separate doctrees so avoid sphinx clashes. | Chris Johns | 2016-11-03 | 1 | -10/+11 |
* | pdf: Make the copyright the same as the html. | Chris Johns | 2016-11-03 | 1 | -1/+1 |
* | conf: Make the build date use a nicer day format. | Chris Johns | 2016-11-03 | 1 | -1/+16 |
* | waf: Have configure set building pdf and/or singlehtml. | Chris Johns | 2016-11-03 | 1 | -206/+247 |
| | | | | | | | | | | | | | | Move selecting pdf and singlehtml to the configure stage so it is sticky for all builds. This means a top level build will always build all formats that have been configured. Do not complete the configure stage if tools are missing for the configured output. Add singlehtml support using the inliner tool. It is nice. Remove the groups as waf can track the dependences. This lets the manuals build in parallel. | ||||
* | Add a copyright to the PDF front page. | Chris Johns | 2016-11-02 | 2 | -3/+4 |
* | html: Update the CSS and add topics. | Chris Johns | 2016-11-02 | 1 | -8/+30 |
* | waf: Fix the sphinx verbose option. | Chris Johns | 2016-11-02 | 1 | -2/+8 |
* | waf: Add an install command. | Chris Johns | 2016-10-31 | 1 | -43/+67 |
* | waf: Add top build support. | Chris Johns | 2016-10-30 | 1 | -16/+44 |
* | waf: Add a build date to the copyright. | Chris Johns | 2016-10-30 | 1 | -1/+2 |
* | waf: Update to support a recent waf. | Chris Johns | 2016-10-29 | 1 | -2/+2 |
* | common/waf.py: Improve Sphinx version parsing to work with their git master | Joel Sherrill | 2016-10-27 | 1 | -2/+2 |
* | waf: Fix for waf-1.9.3. | Chris Johns | 2016-09-09 | 1 | -1/+1 |
* | Make the Warning colours match the theme. | Chris Johns | 2016-07-04 | 1 | -0/+12 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 1 | -4/+16 |
* | Updates from user reviews. | Chris Johns | 2016-05-02 | 1 | -0/+1 |
* | Remove the minted gobble. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 2016-05-02 | 3 | -1/+11 |
* | Add Minted 2015/12/21 v2.2dev (ce7a111) | Amar Takhar | 2016-05-02 | 1 | -0/+1513 |
* | Better error message, add FTP to the URL list. | Chris Johns | 2016-05-02 | 1 | -1/+2 |
* | Format the index for PDF output. | Chris Johns | 2016-05-02 | 1 | -0/+4 |
