2019-03-01 | waf: Fix argument bug getting extra source. | Chris Johns | 1 | -1/+1 | |
2019-02-28 | waf: Add support for extra and excluded sources. | Chris Johns | 1 | -14/+32 | |
2019-02-28 | waf: Change --sphinx-verbose to --sphinx-options, add --sphinx-nit-pick | Chris Johns | 1 | -13/+28 | |
Provide options to manage sphinx. Make using the nit-picky mode simpler to access. | |||||
2019-02-28 | waf: Fix building the images in the src path. | Chris Johns | 1 | -2/+1 | |
2019-02-06 | Fix building with Sphinx 1.8 and later. | Chris Johns | 1 | -11/+28 | |
- Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | |||||
2019-01-09 | Replace build date with Git hash and commit date | Sebastian Huber | 1 | -20/+2 | |
The usage of a build date prevents reproducible builds. | |||||
2018-12-18 | common/waf.py: Fix indentation. | Christian Mauderer | 1 | -1/+1 | |
Python 3 produces an error if indentation is mixed tabs and spaces. | |||||
2018-12-05 | Fix error messages when Sphinx version cannot be checked. | Amar Takhar | 1 | -2/+2 | |
This is kind of a dual-check since it checks for the version while simultaneously checking to see if Sphinx exists on the system. Changed the error messages to be clear on the error and removed a reference to version which cannot be set due to the check failure. Reported by: Shashvat Jain | |||||
2018-11-03 | waf: Add support to build PlantUML and Ditaa images. | Chris Johns | 1 | -1/+69 | |
2018-08-21 | waf: Fix type in single html build. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 1 | -32/+44 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-03-09 | RTEMS Docs: Check sphinx version | Richard Campbell | 1 | -4/+23 | |
Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | |||||
2017-10-12 | build: Add extra source to the sphinx build. | Chris Johns | 1 | -11/+11 | |
Updates #3177. | |||||
2017-08-11 | coverpage: Fix repeated entries. | Chris Johns | 1 | -2/+2 | |
Closes #2865. | |||||
2017-08-09 | Revert "Add the sphinxcontrib.bibtex extension to the repo." | Chris Johns | 1 | -0/+1 | |
This reverts commit aa4f8e2e436d6c49e1524a4a3fb164b28632d894. The contrib has too many dependencies to add into the repo. | |||||
2017-08-07 | Add the sphinxcontrib.bibtex extension to the repo. | Chris Johns | 1 | -1/+0 | |
2017-03-27 | Add Windows build details. | Chris Johns | 1 | -1/+1 | |
Actually include the quoting fix for Windows. | |||||
2017-03-27 | waf: Fix linkcheck and spell commands. | Chris Johns | 1 | -45/+19 | |
Clean up and remove code that is not needed. Fix sphinx-build quoting to work on Windows. | |||||
2017-03-21 | waf: Create the sphinx rule in one place. | Chris Johns | 1 | -11/+11 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -11/+32 | |
2017-03-15 | waf: Configure check the inliner only once. | Chris Johns | 1 | -5/+7 | |
2017-02-25 | Add a check for Sphinx extensions. | Chris Johns | 1 | -15/+44 | |
Minor clean up of the configure messages. Do not re-check sphinx in the nested configures. | |||||
2017-01-10 | waf: Add a title to the XML Catalogue. | Chris Johns | 1 | -1/+6 | |
2017-01-10 | waf: Improved XML Catalogue generator. | Chris Johns | 1 | -44/+41 | |
2017-01-09 | waf: Create an XML Catalogue. | Chris Johns | 1 | -0/+78 | |
2016-11-09 | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 1 | -1/+4 | |
build PDF. | |||||
2016-11-08 | waf: Use the good fonts if installed. | Chris Johns | 1 | -6/+12 | |
2016-11-06 | waf: Add support to handle missing Latex packages on hosts they are not ↵ | Chris Johns | 1 | -95/+21 | |
available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font. | |||||
2016-11-04 | waf: Check for texlive packages and report an error is not found. | Chris Johns | 1 | -6/+106 | |
2016-11-04 | waf: Fix the bnode issue when building in a manual directory. | Chris Johns | 1 | -1/+1 | |
2016-11-03 | waf: Use separate doctrees so avoid sphinx clashes. | Chris Johns | 1 | -10/+11 | |
2016-11-03 | waf: Have configure set building pdf and/or singlehtml. | Chris Johns | 1 | -206/+247 | |
Move selecting pdf and singlehtml to the configure stage so it is sticky for all builds. This means a top level build will always build all formats that have been configured. Do not complete the configure stage if tools are missing for the configured output. Add singlehtml support using the inliner tool. It is nice. Remove the groups as waf can track the dependences. This lets the manuals build in parallel. | |||||
2016-11-02 | waf: Fix the sphinx verbose option. | Chris Johns | 1 | -2/+8 | |
2016-10-31 | waf: Add an install command. | Chris Johns | 1 | -43/+67 | |
2016-10-30 | waf: Add top build support. | Chris Johns | 1 | -16/+44 | |
2016-10-29 | waf: Update to support a recent waf. | Chris Johns | 1 | -2/+2 | |
2016-10-27 | common/waf.py: Improve Sphinx version parsing to work with their git master | Joel Sherrill | 1 | -2/+2 | |
2016-09-09 | waf: Fix for waf-1.9.3. | Chris Johns | 1 | -1/+1 | |
2016-05-18 | Move images to a common directory. | Amar Takhar | 1 | -4/+16 | |
2016-05-02 | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 1 | -0/+2 | |
2016-05-02 | Run through 2to3. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Generate a fatal error on a Sphinx beta version that cannot be parsed. | Chris Johns | 1 | -3/+5 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+15 | |
2016-05-02 | Remove incorrect pdflatex/makeindex check. | Amar Takhar | 1 | -4/+0 | |
2016-05-02 | Only require makeindex and pdflatex when trying to build PDF. | Amar Takhar | 1 | -3/+3 | |
2016-05-02 | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 1 | -36/+62 | |
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | |||||
2016-05-02 | Fix typo and add another dependency. | Amar Takhar | 1 | -2/+2 | |
2016-05-02 | Add minimum version check for Sphinx. | Amar Takhar | 1 | -1/+24 | |
Some distributions have ancient versions we require at least 1.3. | |||||
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -16/+47 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -2/+35 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. |
