* This is still broken.
* Rename sphinx_rtd_theme so it doesn't pickup locally installed ones
* Add a hack to theme.css to get around inliner bug.
* Some unrelated fixups in common/waf.py
Unfortunatly several dozen fixes got merged into this.
Some distributions have ancient versions we require at least 1.3.
To use:
1. Install aspell
2. waf spell <list of files>
* waf spell mydoc.rst
* waf spell *.rst
This uses a custom dictionary stored in common/spell/dict/. We should add all
RTEMS and programming terms to this to ensure we are consistent.
Amar.
Needed to switch due to increasing complexity.
