* | latex: Increase the depth of subsections. | Chris Johns | 2016-11-09 | 1 | -4/+7 |
* | waf: Use the good fonts if installed. | Chris Johns | 2016-11-08 | 1 | -12/+1 |
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 1 | -1/+6 |
* | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 2016-11-07 | 1 | -3/+5 |
* | pdf: Make the copyright the same as the html. | Chris Johns | 2016-11-03 | 1 | -1/+1 |
* | Add a copyright to the PDF front page. | Chris Johns | 2016-11-02 | 1 | -1/+1 |
* | Updates from user reviews. | Chris Johns | 2016-05-02 | 1 | -0/+1 |
* | Remove the minted gobble. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 2016-05-02 | 1 | -0/+8 |
* | Format the index for PDF output. | Chris Johns | 2016-05-02 | 1 | -0/+4 |
* | Wrap \tabulary environment to allow breaking underscores. | Amar Takhar | 2016-05-02 | 1 | -0/+9 |
| | | | | * This \discretionary to avoid language issues. | ||||
* | Fix PDF layout. | Chris Johns | 2016-05-02 | 1 | -0/+2 |
* | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 2016-05-02 | 1 | -2/+3 |
| | | | | | | | | | * This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | ||||
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 1 | -0/+119 |
