* | common: Remove probably superfluous import | Sebastian Huber | 2020-07-08 | 1 | -1/+0 |
| | | | | | | | | | The purpose of this import is unclear. This import caused the following error with Sphinx 3.0: Extension error: Could not import extension rtemsdomain (exception: cannot import name 'l_') | ||||
* | Revert "common: Add URLs to manuals" | Sebastian Huber | 2020-02-04 | 1 | -13/+1 |
| | | | | | This reverts commit 1fdd3cf83d154af66ad0edf5094d93075063c7e0 and some follow up changes. | ||||
* | common: Add URLs to manuals | Sebastian Huber | 2020-01-07 | 1 | -1/+13 |
* | common: Align "Build Logs" with other list names | Sebastian Huber | 2019-08-05 | 1 | -1/+1 |
* | RTEMS Docs: Check sphinx version | Richard Campbell | 2018-03-09 | 1 | -1/+0 |
| | | | | | | | Sphinx.util.compat module was removed at Sphinx version 1.7. Imported module was not being used. Closes #3311. | ||||
* | Better error message, add FTP to the URL list. | Chris Johns | 2016-05-02 | 1 | -1/+2 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 1 | -0/+126 |
