2023-11-09 | eng: Add formal verification chapter | Andrew Butterfield | 1 | -0/+75 | |
2019-07-24 | refs: Update EARS references | Sebastian Huber | 1 | -2/+20 | |
2019-07-23 | refs: Add ECSS standard references | Sebastian Huber | 1 | -0/+51 | |
Add the ECSS standards in a separate block. Use a custom label scheme to make citations easier. | |||||
2019-07-23 | refs: Replace non-ASCII character | Sebastian Huber | 1 | -1/+1 | |
2019-07-11 | common: Add references | Sebastian Huber | 1 | -0/+49 | |
2019-06-21 | c-user: Add RTEID and ORKID references | Sebastian Huber | 1 | -0/+18 | |
2017-02-02 | c-user: Add SMP application issues section | Sebastian Huber | 1 | -0/+4 | |
2017-02-02 | c-user: Update clustered scheduling | Sebastian Huber | 1 | -7/+34 | |
2017-02-01 | Fix refs.bib entries | Sebastian Huber | 1 | -1/+2 | |
2017-02-01 | c-user: Add Key concept locking protocols | Sebastian Huber | 1 | -0/+16 | |
Update #2412. Update #2556. | |||||
2017-01-31 | Fix refs.bib entry | Sebastian Huber | 1 | -1/+2 | |
2017-01-30 | refs.bib: Add URL | Sebastian Huber | 1 | -0/+1 | |
2017-01-30 | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 1 | -1/+66 | |
State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | |||||
2017-01-25 | Fix some reference titles | Sebastian Huber | 1 | -3/+3 | |
2017-01-25 | Sort references | Sebastian Huber | 1 | -108/+110 | |
2017-01-18 | c-user: Add support for references via bibtex | Sebastian Huber | 1 | -0/+173 | |
https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. |
