* | Fix the linux specific include | Chris Johns | 2021-05-21 | 1 | -4/+4 |
* | common/latex.py: use distro module for python3.5 and up | Vijay Kumar Banerjee | 2021-03-30 | 1 | -2/+5 |
* | common/latex.py: Remove hack for CentOS. Use Texlive per instructions. | Joel Sherrill | 2019-02-13 | 1 | -8/+0 |
* | c-user: Add timer and timeouts key concept | Sebastian Huber | 2017-01-30 | 1 | -0/+1 |
| | | | | Update #2554. | ||||
* | waf: Users without the extra fonts need to use '--disable-extra-fonts' to ↵ | Chris Johns | 2016-11-09 | 1 | -1/+2 |
| | | | | build PDF. | ||||
* | waf: Get a copy of the optional packages. | Chris Johns | 2016-11-08 | 1 | -2/+2 |
* | waf: Use the good fonts if installed. | Chris Johns | 2016-11-08 | 1 | -4/+24 |
* | pdf: Format lists for directives to sit on the next line. | Chris Johns | 2016-11-08 | 1 | -0/+1 |
* | PDF: Do not use lato and inconsolata fonts. Not widely supported. | Chris Johns | 2016-11-07 | 1 | -4/+0 |
* | waf: Add a program test for pygmentize. | Chris Johns | 2016-11-07 | 1 | -0/+3 |
* | waf: Fix ''NoneType' object is not iterable' | Christian Mauderer | 2016-11-07 | 1 | -4/+6 |
* | waf: Fix the host version check. | Chris Johns | 2016-11-06 | 1 | -3/+3 |
* | waf: Add support to handle missing Latex packages on hosts they are not ↵ | Chris Johns | 2016-11-06 | 1 | -0/+145 |
available on. It appears the support for texlive packages on some hosts is variable. This patch lets us add missing packages to our source tree so a PDF can be built on those hosts. The quality of the PDFs created may vary as some short cuts may have been take. For example lato is a font and only the sty file as been added and not the actual font which means it's use will default to another font. |
