2019-02-13 | Remove minted from the PDF builds. | Chris Johns | 1 | -1/+1 | |
This is feedback from the Sphinx project. See: https://github.com/sphinx-doc/sphinx/issues/6021#issuecomment-460951653 | |||||
2019-02-06 | Fix building with Sphinx 1.8 and later. | Chris Johns | 1 | -3/+5 | |
- Provide the pytnon.ist file for makeindex. - Add support for xelatex building so we can switch if we want too. Closes #3669 | |||||
2019-01-18 | Change first copyright year to 1988 | Sebastian Huber | 1 | -1/+1 | |
The OAR copyright goes back to 1988. | |||||
2019-01-09 | Update general copyright notice | Sebastian Huber | 1 | -1/+1 | |
Update year and add "and contributors". | |||||
2019-01-09 | Replace build date with Git hash and commit date | Sebastian Huber | 1 | -24/+1 | |
The usage of a build date prevents reproducible builds. | |||||
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-08-21 | pdf: Revert the changes to the Latex index formatting. | Chris Johns | 1 | -1/+0 | |
I removed the '_' splitting of long labels from the index when testing and this puts it back. | |||||
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 1 | -2/+4 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2017-08-25 | common: Remove obsolete latex_use_parts | Sebastian Huber | 1 | -4/+0 | |
This configuration is obsolete and no longer documented: http://www.sphinx-doc.org/en/stable/config.html#options-for-latex-output The use of parts at the top-level results in ugly documents. | |||||
2017-08-11 | common/conf: Clean up. | Chris Johns | 1 | -4/+0 | |
2017-03-21 | conf: Update the copyright year. | Chris Johns | 1 | -2/+7 | |
2017-03-20 | Use a single top level version number. | Chris Johns | 1 | -3/+3 | |
2017-02-22 | Move extensions to common conf.py | Sebastian Huber | 1 | -1/+2 | |
2017-02-01 | Do not show page references after internal links | Sebastian Huber | 1 | -1/+1 | |
2017-01-11 | conf.py: Fix build_date() to append correct suffix on all days. | Justin Powell | 1 | -1/+7 | |
2016-11-08 | pdf: Format lists for directives to sit on the next line. | Chris Johns | 1 | -1/+0 | |
2016-11-03 | conf: Make the build date use a nicer day format. | Chris Johns | 1 | -1/+16 | |
2016-11-02 | Add a copyright to the PDF front page. | Chris Johns | 1 | -2/+3 | |
2016-10-30 | waf: Add a build date to the copyright. | Chris Johns | 1 | -1/+2 | |
2016-05-02 | Switch to using Minted and splitting long lines in verbatim. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Fix PDF layout. | Chris Johns | 1 | -2/+2 | |
2016-05-02 | Add my-style.css support and add RTEMS to that CSS. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Add support for singlehtml (inlined) HTML file, plus some other fixes. | Amar Takhar | 1 | -49/+9 | |
* This is still broken. * Rename sphinx_rtd_theme so it doesn't pickup locally installed ones * Add a hack to theme.css to get around inliner bug. * Some unrelated fixups in common/waf.py Unfortunatly several dozen fixes got merged into this. | |||||
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -8/+7 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Fix rtemsconfig building. | Amar Takhar | 1 | -0/+2 | |
I'll probably move to a more pythonic way of doing conf.py since this is getting too complicated. |
