* | Remove the old files. | Chris Johns | 2016-10-29 | 1 | -23788/+0 |
* | object_services.rst: Add _rtems_object_id_api_minimum_class and ↵ | Joel Sherrill | 2016-10-28 | 2 | -1/+67 |
| | | | | _rtems_object_id_api_maximum_class | ||||
* | c_user: Remove errors and warnings. | Chris Johns | 2016-10-28 | 11 | -22/+338 |
* | rtems-docs: Fix many unnecessary back slashes | Joel Sherrill | 2016-10-27 | 2 | -2/+2 |
* | c_user: Fix minor error. | Chris Johns | 2016-09-14 | 1 | -1/+1 |
* | Set SPDX License Identifier in each source file. | Chris Johns | 2016-05-20 | 40 | -0/+80 |
* | Move images to a common directory. | Amar Takhar | 2016-05-18 | 7 | -4/+4 |
* | Fix SMP warning. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Update version numbers and the titles. | Chris Johns | 2016-05-02 | 1 | -3/+4 |
* | Fix formatting. | Chris Johns | 2016-05-02 | 1 | -1/+1 |
* | Minor fixes. | Chris Johns | 2016-05-02 | 5 | -10/+9 |
* | Clean up. | Chris Johns | 2016-05-02 | 1 | -417/+320 |
* | Change code to code-block. | Chris Johns | 2016-05-02 | 27 | -267/+213 |
* | Fix double quotes. | Chris Johns | 2016-05-02 | 1 | -4/+4 |
* | Clean up. | Chris Johns | 2016-05-02 | 10 | -1227/+1638 |
* | Add semaphore attributes figure. | Chris Johns | 2016-05-02 | 2 | -3/+4 |
* | Fix the double quotes. | Chris Johns | 2016-05-02 | 9 | -41/+44 |
* | Manually apply patch from textinfo dooc. | Chris Johns | 2016-05-02 | 1 | -2/+2 |
| | | | | Patch https://git.rtems.org/rtems/commit/?id=265312a5be98d59e9758cc78c0f313920fa40016 | ||||
* | Clean up | Chris Johns | 2016-05-02 | 6 | -1738/+1781 |
* | Clean ups. | Chris Johns | 2016-05-02 | 12 | -2497/+2647 |
* | Add an rtems-table class to wrap and align HTML tables. | Chris Johns | 2016-05-02 | 5 | -10/+72 |
* | Cleanups. | Chris Johns | 2016-05-02 | 6 | -736/+744 |
* | Fix index error. | Chris Johns | 2016-05-02 | 1 | -1/+2 |
* | Remove widths from tables for the PDF. | Chris Johns | 2016-05-02 | 1 | -21/+0 |
* | Fix PDF layout. | Chris Johns | 2016-05-02 | 1 | -10/+6 |
* | Switch the task manager to tables for status codes. | Chris Johns | 2016-05-02 | 1 | -262/+252 |
* | Remove command.rst and clean up the index page. | Chris Johns | 2016-05-02 | 2 | -26/+23 |
* | C user guide clean up. Up to timer manager. | Chris Johns | 2016-05-02 | 14 | -3445/+3539 |
* | Add 'waf linkcheck' to check external references. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
* | Add PDF generation support use with --pdf | Amar Takhar | 2016-05-02 | 2 | -6/+13 |
* | Add support for spellchecking with a custom dictionary. | Amar Takhar | 2016-05-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | ||||
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 35 | -308/+308 |
* | Rework how conf.py is handled. | Amar Takhar | 2016-05-02 | 1 | -9/+1 |
| | | | | Needed to switch due to increasing complexity. | ||||
* | Rename old document for reference only. | Amar Takhar | 2016-05-02 | 1 | -0/+0 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 40 | -1/+23750 |
* | Fix markup. | Amar Takhar | 2016-05-02 | 1 | -122/+173 |
* | Initial reST documentation using Sphinx. | Amar Takhar | 2016-05-02 | 3 | -0/+23755 |
