2016-05-02 | Fix SMP warning. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Update version numbers and the titles. | Chris Johns | 1 | -3/+4 | |
2016-05-02 | Fix formatting. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Minor fixes. | Chris Johns | 5 | -10/+9 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -417/+320 | |
2016-05-02 | Change code to code-block. | Chris Johns | 27 | -267/+213 | |
2016-05-02 | Fix double quotes. | Chris Johns | 1 | -4/+4 | |
2016-05-02 | Clean up. | Chris Johns | 10 | -1227/+1638 | |
2016-05-02 | Add semaphore attributes figure. | Chris Johns | 2 | -3/+4 | |
2016-05-02 | Fix the double quotes. | Chris Johns | 9 | -41/+44 | |
2016-05-02 | Manually apply patch from textinfo dooc. | Chris Johns | 1 | -2/+2 | |
Patch https://git.rtems.org/rtems/commit/?id=265312a5be98d59e9758cc78c0f313920fa40016 | |||||
2016-05-02 | Clean up | Chris Johns | 6 | -1738/+1781 | |
2016-05-02 | Clean ups. | Chris Johns | 12 | -2497/+2647 | |
2016-05-02 | Add an rtems-table class to wrap and align HTML tables. | Chris Johns | 5 | -10/+72 | |
2016-05-02 | Cleanups. | Chris Johns | 6 | -736/+744 | |
2016-05-02 | Fix index error. | Chris Johns | 1 | -1/+2 | |
2016-05-02 | Remove widths from tables for the PDF. | Chris Johns | 1 | -21/+0 | |
2016-05-02 | Fix PDF layout. | Chris Johns | 1 | -10/+6 | |
2016-05-02 | Switch the task manager to tables for status codes. | Chris Johns | 1 | -262/+252 | |
2016-05-02 | Remove command.rst and clean up the index page. | Chris Johns | 2 | -26/+23 | |
2016-05-02 | C user guide clean up. Up to timer manager. | Chris Johns | 14 | -3445/+3539 | |
2016-05-02 | Add 'waf linkcheck' to check external references. | Amar Takhar | 1 | -1/+1 | |
2016-05-02 | Add PDF generation support use with --pdf | Amar Takhar | 2 | -6/+13 | |
2016-05-02 | Add support for spellchecking with a custom dictionary. | Amar Takhar | 1 | -1/+1 | |
To use: 1. Install aspell 2. waf spell <list of files> * waf spell mydoc.rst * waf spell *.rst This uses a custom dictionary stored in common/spell/dict/. We should add all RTEMS and programming terms to this to ensure we are consistent. Amar. | |||||
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 35 | -308/+308 | |
2016-05-02 | Rework how conf.py is handled. | Amar Takhar | 1 | -9/+1 | |
Needed to switch due to increasing complexity. | |||||
2016-05-02 | Rename old document for reference only. | Amar Takhar | 1 | -0/+0 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 40 | -1/+23750 | |
2016-05-02 | Fix markup. | Amar Takhar | 1 | -122/+173 | |
