* | Change code to code-block. | Chris Johns | 2016-05-02 | 1 | -5/+5 |
* | Fix the double quotes. | Chris Johns | 2016-05-02 | 1 | -2/+4 |
* | Manually apply patch from textinfo dooc. | Chris Johns | 2016-05-02 | 1 | -2/+2 |
| | | | | Patch https://git.rtems.org/rtems/commit/?id=265312a5be98d59e9758cc78c0f313920fa40016 | ||||
* | Clean up | Chris Johns | 2016-05-02 | 1 | -1/+3 |
* | Cleanups. | Chris Johns | 2016-05-02 | 1 | -3/+3 |
* | Fix index error. | Chris Johns | 2016-05-02 | 1 | -1/+2 |
* | C user guide clean up. Up to timer manager. | Chris Johns | 2016-05-02 | 1 | -200/+169 |
* | Convert all Unicode to ASCII(128) | Amar Takhar | 2016-05-02 | 1 | -11/+11 |
* | Split document into seperate files by section. | Amar Takhar | 2016-05-02 | 1 | -0/+338 |
