2024-03-20 | c-user: Clarify CONFIGURE_TICKS_PER_TIMESLICE | Sebastian Huber | 1 | -1/+1 | |
Close #4986. | |||||
2023-12-19 | c-user: CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY | Sebastian Huber | 1 | -1/+36 | |
Document CONFIGURE_JFFS2_DELAYED_WRITE_TASK_PRIORITY. Update #4961. | |||||
2023-12-19 | glossary: Add terms | Sebastian Huber | 1 | -0/+54 | |
2023-08-09 | Add Regulator documentation based on V1 functionality | Joel Sherrill | 7 | -0/+846 | |
2023-07-28 | c-user: Clarify global construction | Sebastian Huber | 1 | -10/+15 | |
2023-07-25 | c-user: Link task entry and global construction | Sebastian Huber | 6 | -7/+29 | |
2023-07-20 | c-user: Add glossary terms for SPARC targets | Sebastian Huber | 1 | -0/+30 | |
2023-07-20 | c-user: Fix typo | Sebastian Huber | 1 | -1/+1 | |
Updates #4772. | |||||
2023-07-20 | c-user: Update copyright and use glossary terms | Sebastian Huber | 2 | -4/+4 | |
2023-07-06 | c-user: Update references to rtems_task_wake_after | Kinsey Moore | 4 | -20/+25 | |
rtems_task_wake_after takes a parameter in terms of a count of clock ticks and not a measure in a subunit of seconds. This updates documentation to reflect that. This also makes obvious the caveat about the first tick wait not being a whole tick and points the user at a replacement for better accuracy. Updates #4772 | |||||
2023-05-20 | Update company name | Sebastian Huber | 91 | -91/+91 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-05-09 | c-user: Generate API type documentation | Sebastian Huber | 19 | -320/+1729 | |
Close #4901. | |||||
2023-03-28 | c-user/smp: Fix item rendering | Kinsey Moore | 1 | -1/+1 | |
2023-03-09 | c-user/chains: Correct iteration example code | Kinsey Moore | 1 | -2/+3 | |
Casting the node returned by rtems_chain_head is incorrect. That node is owned by the control structure and use of it post-cast could cause memory corruption. Instead, use rtems_chain_first which returns the node after the head node. This also corrects node->next to rtems_chain_next(node) which makes better use of the API. | |||||
2023-02-14 | c-user: Use configuration option references | Sebastian Huber | 1 | -31/+32 | |
2023-02-14 | c-user: Document CONFIGURE_INIT | Sebastian Huber | 2 | -2/+38 | |
2023-02-14 | c-user: Fix header file path | Sebastian Huber | 1 | -2/+3 | |
2023-02-14 | c-user: Harmonize header file references | Sebastian Huber | 3 | -10/+10 | |
2023-02-14 | c-user: Remove obsolete config section | Sebastian Huber | 2 | -356/+0 | |
This commit already clarified that the defines of the removed section are optional BSP provided default values and not application configuration options: commit cf9f2121577b11f8eab5e49c48173c46cf09c627 Author: Sebastian Huber <sebastian.huber@embedded-brains.de> Date: Wed Nov 17 08:46:56 2021 +0100 c-user: Clarify BSP related configuration settings | |||||
2023-01-23 | c-user/message/directives.rst: byes->bytes typo | Martin Erik Werner | 1 | -1/+1 | |
2023-01-13 | c-user/rate-monotonic/background.rst: Correct logically inverted statement | Joel Sherrill | 1 | -5/+6 | |
Also corrected a spot of formatting. Closes #4781. | |||||
2022-12-07 | c-user: Add Local vs Global to Key Concepts Chapter | Joel Sherrill | 1 | -8/+68 | |
Add multiple new index entries and cite them where RTEMS_LOCAL and RTEMS_GLOBAL are cited. Closes #4453. | |||||
2022-12-02 | Document CONFIGURE_RECORD_INTERRUPTS_ENABLED | Sebastian Huber | 1 | -1/+42 | |
Close #4769. | |||||
2022-11-30 | c-user/*: Add trailing parentheses on methods in index which were missing it | Joel Sherrill | 11 | -71/+71 | |
Closes #4766. | |||||
2022-11-08 | c-user: Adjust URL for struct timespec | Sebastian Huber | 1 | -5/+4 | |
2022-11-08 | c-user/clock: Fix typo | Matt Joyce | 1 | -1/+1 | |
2022-10-14 | c-user: INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL | Sebastian Huber | 1 | -0/+7 | |
Document this fatal error. | |||||
2022-10-14 | c-user: INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STORAGE | Sebastian Huber | 1 | -0/+5 | |
2022-10-14 | c-user: INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED | Sebastian Huber | 1 | -0/+5 | |
2022-10-14 | c-user: Add CONFIGURE_IDLE_TASK_STORAGE_SIZE | Sebastian Huber | 2 | -11/+101 | |
2022-10-06 | c-user: Fix references | Sebastian Huber | 1 | -10/+5 | |
2022-10-06 | c-user: INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED | Sebastian Huber | 1 | -3/+8 | |
2022-10-06 | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2 | -63/+63 | |
Move CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE to the general configuration options. | |||||
2022-10-04 | c-user: Add application config info directives | Sebastian Huber | 13 | -96/+1832 | |
Close #4267. Close #4269. | |||||
2022-10-04 | c-user: Add types to macros | Sebastian Huber | 4 | -22/+44 | |
2022-09-29 | c-user: Add type roles | Sebastian Huber | 1 | -6/+6 | |
2022-09-05 | c-user/config/face.rst: New file -- add CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR | Joel Sherrill | 2 | -0/+77 | |
Closes #4691. | |||||
2022-08-31 | c-user: Clarify BSP related configuration settings | Sebastian Huber | 3 | -9/+76 | |
2022-08-11 | c-user: Update OAR copyright and reformat | Sebastian Huber | 3 | -14/+10 | |
These files are generated by a script. | |||||
2022-07-28 | c-user: Document new rtems_task_delete() behaviour | Sebastian Huber | 1 | -5/+20 | |
Update #4679. | |||||
2022-07-28 | c-user: Document task life states | Sebastian Huber | 1 | -1/+53 | |
2022-07-26 | c-user: Do not mention pseudo-interrupt priority | Sebastian Huber | 2 | -3/+4 | |
Update #2365. | |||||
2022-05-20 | c-user: Update references to --enable-* configure options. | Joel Sherrill | 4 | -30/+44 | |
Also updated list of SMP architectures and added enough lead in to let users know the source code was the definitive answer. | |||||
2022-03-30 | c-user: Clarify scheduler of created task | Sebastian Huber | 1 | -3/+3 | |
2022-03-16 | c-user: Improve interrupt set affinity handling | Sebastian Huber | 2 | -2/+7 | |
Update #3269. | |||||
2022-02-22 | c-user: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES | Sebastian Huber | 1 | -3/+90 | |
Update #4524. | |||||
2022-01-11 | c-user: Use document internal links | Sebastian Huber | 1 | -10/+12 | |
2022-01-11 | c-user: Clarify Clock Manager dependencies | Sebastian Huber | 1 | -8/+16 | |
Update #4572. | |||||
2021-12-16 | c-user: Clarify time formats | Sebastian Huber | 1 | -12/+27 | |
2021-12-16 | c-user: Fix Clock Manager parameter descriptions | Sebastian Huber | 1 | -17/+21 | |
Update #4572. |
