Close #4482.
This global object no longer exists.
Close #3269.
Mention the type of the pointer in the parameter description. Use the
more general term "object" instead of "variable".
Update #3993.
Closes #4440.
Close #4414.
Update #4406.
Document changed error status.
Update #4401.
Document new error status.
If only one constraint is present, then use a single sentence, otherwise
use a list for the constraints. Format the constraints so that the line
length limit is maintained.
Replace copy and paste with a proper description.
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #4392.
Update #3993.
Update #3993.
A timer may be also reinitiated by the timer server fire directives.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
This makes it easier to automatically generate parts of the module
documentation in the future.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Add glossary terms which characterize the relationship of a scheduler to
a task.
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Update #4346.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
This makes it easier to automatically generate parts of the manager
Update #3993.
Update #3993.
