Sort the configuration option groups according to the likelihood a user
will define options of a group.
Update #3836.
The help macro CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE() is not a
configuration option. Move it into the documentatation of the
CONFIGURE_MESSAGE_BUFFER_MEMORY configuration option. Move this option
to the general system configuration group.
Update #3836.
Add copyright information according to commit in RTEMS main repository:
commit e53aae2676c42cda521328504f82d26c33827021
Author: Gedare Bloom <gedare@rtems.org>
Date: Mon Mar 26 16:42:38 2012 -0400
confdefs: Add declaration for unlimited objects.
Adds to confdefs a way to specify rtems_resource_unlimited for classic and
posix objects using a new macro CONFIGURE_OBJECTS_UNLIMITED.
Use CONFIGURE_OBJECTS_ALLOCATION_SIZE to declare the allocation size for
extending the set of objects at runtime. Updates the unlimited sample
to demonstrate how to use the new macros. Also adds new documentation in
the C User's Manual regarding configuring with unlimited objects.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Introduce an index file for this chapter. This helps to generate some
sections from the specification in the future. Start with moving
"Introduction" up to "Unlimited Objects" to a new file.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Update #3836.
Sort options alphabetically.
Update #3836.
The content introduced by a commit in the RTEMS main repository
commit 418de420a05609ba8919822b553706963a8d3a7b
Author: Joel Sherrill <joel.sherrill@OARcorp.com>
Date: Wed Oct 5 19:59:47 2011 +0000
2011-10-05 Joel Sherrill <joel.sherrill@oarcorp.com>
Petr Benes <benesp16@fel.cvut.cz>
PR 1912/doc
* user/conf.t, user/schedule.t: Rework to add scheduler specific
information.
is no longer in this file. According to the file history, this was the
only content introduced by Petr Benes. Also during the relicensing of
the documentation to CC-BY-SA-4.0 in 2016 it was proclaimed that OAR was
the only copyright holder of the RTEMS documentation present in the
RTEMS main repository.
Update #3836.
Remove a spurious "is undefined. " fragment which was likely a leftover
from sentence re-use.
Add a description of the previously missing RTEMS_NOT_DEFINED return
value for rtems_rate_monotonic_get_status().
Update the RTEMS_SUCCESSFUL return value descriptions for
rtems_rate_monotonic_get_status() and
rtems_rate_monotonic_get_statistics() which incorrectly used the same
description as rtems_rate_monotonic_period().
Close #3835.
Close #3885.
Close #3881.
Update #3881.
Update #3853.
Use the file history to derive the copyright information.
Update #3853.
Update #3853.
Update #3853.
Remove duplicate "return code" definition. Add all related terms and
use references.
Update #3853.
Four spaces per indent level is used in most files.
Update #3853.
Add :term: text roles to acronym definitions of glossary defined terms.
Update #3853.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Close #3874.
Using CONFIGURE_HAS_OWN_INIT_TASK_TABLE would have required the use of
the undocumented CONFIGURE_INIT_TASK_TABLE and
CONFIGURE_INIT_TASK_TABLE_SIZE configuration options.
Close #3873.
Define exactly one term per definition. Use references for alternative
terms. Add :term: text roles to acronym definitions of glossary defined
terms.
Update #3853.
Update #3875.
Update #3875.
