Update #3993.
Add glossary terms which characterize the relationship of a scheduler to
a task.
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Update #4346.
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup. The documentation was
transfered to interface specification items. The documentation source
files were generated from the items by a script.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
This makes it easier to automatically generate parts of the manager
documentation in the future.
Update #3993.
Update #3993.
Update #3993.
Unify the wording across similar directives of other managers.
Update #3993.
Update #3993.
Unify the wording across similar directives of other managers. Add
"CONSTRAINTS" section.
Update #3993.
Update #3993.
Update #3993.
Add a "Constraints" paragraph to the documentation. Use function
prototypes for the directives.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Move the PTCB sentence to the notes to be in line with
rtems_partition_create().
Update #3993.
The rtems_partition_create() returns an object identifier and not just a
partition identifier.
Update #3993.
Update #3993.
Document new configuration option
CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE.
Close #4181.
This makes it easier to automatically generate parts of the module
Update #3993.
The manager documentation is a consolidation of the comments in Doxygen
markup and the documentation sources in Sphinx markup. The
documentation was transfered to interface specification items. This
header file was generated from the items by a script.
Update #3993.
Update #3993.
Update #3993.
Document this application configuration option.
Update #3959.
Close #4074.
Introduce a background section.
This makes it easier to automatically generate parts of the scheduling
concepts documentation in the future.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
