2019-02-01 | c-user: Add event recording configuration | Sebastian Huber | 1 | -0/+58 | |
Update #3665. | |||||
2019-01-14 | Reformat and update copyright and license notices | Sebastian Huber | 1 | -7/+8 | |
For everything before 2015 an OAR copyright is assumed. Later copyright notices are based on Git commits on a best effort basis. The copyright notices of the "RTEMS Software Engineering Handbook" and the "RTEMS CPU Architecture Supplement" are incomplete. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 41 | -41/+41 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 39 | -39/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 39 | -74/+41 | |
2019-01-09 | Add common header.rst to reduce copy and paste | Sebastian Huber | 1 | -23/+1 | |
2019-01-04 | c-user: Fix typos | Frédéric Jouault | 2 | -4/+4 | |
Close #3261. | |||||
2018-12-10 | c-user: rtems_scheduler_get_maximum_priority() | Sebastian Huber | 1 | -0/+37 | |
Close #3636. | |||||
2018-11-21 | c-user: Remove 16-bit object identifiers | Sebastian Huber | 1 | -36/+8 | |
Close #3603. | |||||
2018-11-16 | c-user: Update type deprecation | Sebastian Huber | 1 | -10/+5 | |
Update #3584. Update #3587. Update #3589. | |||||
2018-11-05 | c-user: Use common wording for build config opts | Sebastian Huber | 2 | -7/+7 | |
2018-11-05 | c-user: Update POSIX API configuration | Sebastian Huber | 1 | -11/+22 | |
Close ##2514. | |||||
2018-10-30 | Document CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 1 | -0/+32 | |
2018-10-29 | c-user/message_manager.rst: Change "cons void" to "const void" | Joel Sherrill | 1 | -1/+1 | |
Closes #3575. | |||||
2018-10-26 | c-user: Clarify scheduler configuration | Sebastian Huber | 3 | -23/+71 | |
2018-10-22 | c-user: Modify CONFIGURE_INTERRUPT_STACK_SIZE | Sebastian Huber | 1 | -12/+29 | |
Use CPU_STACK_MINIMUM_SIZE instead of CONFIGURE_MINIMUM_TASK_STACK_SIZE to set the default value. Clarify documentation. Update #3480. | |||||
2018-10-19 | Update the copyright year. | Chris Johns | 1 | -1/+1 | |
2018-10-11 | c-user/index.rst: Reorder linker sets and directive status codes | Joel Sherrill | 1 | -1/+1 | |
2018-10-05 | barrier_manager.rst: Fix Barrier Wait Section Title | Joel Sherrill | 1 | -2/+2 | |
closes #3538. | |||||
2018-10-04 | c-user: Document rtems_task_exit() | Sebastian Huber | 1 | -1/+46 | |
Close #3533. | |||||
2018-09-17 | Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE | Sebastian Huber | 1 | -26/+7 | |
Close #3489. Close #3490. | |||||
2018-09-17 | c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE | Sebastian Huber | 1 | -33/+7 | |
Close #3488. | |||||
2018-09-10 | c-user: Mention thread pinning | Sebastian Huber | 1 | -0/+22 | |
Close #3508. | |||||
2018-09-10 | c-user: Mention per-processor data | Sebastian Huber | 1 | -0/+18 | |
Close #3507. | |||||
2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-08-11 | c-user: SMP is supported on RISC-V | Sebastian Huber | 1 | -1/+3 | |
Update #3433. | |||||
2018-08-10 | c-user: Adjust integer types in partition create | Sebastian Huber | 1 | -2/+2 | |
Close #3486. | |||||
2018-08-07 | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 1 | -7/+37 | |
Close #3434. | |||||
2018-08-07 | c-user: Sort POSIX configuration options | Sebastian Huber | 1 | -60/+60 | |
2018-08-03 | c-user: Update partition create documentation | Sebastian Huber | 1 | -11/+54 | |
Add an example. Close #3482. | |||||
2018-06-19 | c-user: Document RTEMS_SYSINIT_CPU_COUNTER | Sebastian Huber | 1 | -0/+6 | |
Update #3456. | |||||
2018-06-18 | c-user: Remove obsolete RTEMS_SYSINIT_CPU_SET | Sebastian Huber | 1 | -4/+0 | |
Update #2514. | |||||
2018-06-05 | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 1 | -0/+4 | |
Close #3437. | |||||
2018-06-05 | c-user: Update rtems_region_create() | Sebastian Huber | 1 | -9/+10 | |
2018-05-23 | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2 | -2/+2 | |
2018-05-20 | c-user: changed RTEMS_STATUS_SUCCESSFUL to RTEMS_SUCCESSFUL | Malte Münch | 1 | -2/+2 | |
2018-05-18 | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 1 | -1/+1 | |
2018-05-18 | fix typo: extesion->extension | Malte Münch | 1 | -1/+1 | |
2018-05-18 | c-user: Update manual organization in overview | Malte Münch | 1 | -32/+57 | |
2018-04-30 | c-user: Fix reference | Sebastian Huber | 1 | -6/+6 | |
2018-04-30 | c-user: Fix typo | Sebastian Huber | 1 | -2/+2 | |
2018-03-12 | c-user: Properly fix the previous typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 1 | -45/+54 | |
Close #3325. | |||||
2018-03-09 | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 1 | -1/+1 | |
2018-03-08 | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 1 | -78/+92 | |
Update #3325. | |||||
2018-03-07 | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2 | -151/+185 | |
2018-03-07 | c-user: Use uniprocessor throughout | Sebastian Huber | 7 | -25/+25 | |
2018-03-07 | c-user: Sort scheduler configuration options | Sebastian Huber | 1 | -96/+96 | |
2018-03-07 | c-user: Promote clustered scheduler configuration | Sebastian Huber | 3 | -8/+7 | |
Add own section for the clustered scheduler configuration. |
