2017-03-08 | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 1 | -1/+3 | |
2017-03-07 | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 1 | -31/+39 | |
2017-02-22 | Move extensions to common conf.py | Sebastian Huber | 1 | -2/+0 | |
2017-02-20 | Render math via JavaScript in HTML output | Sebastian Huber | 1 | -1/+1 | |
2017-02-15 | c-user: Fix linker set code blocks | Sebastian Huber | 1 | -12/+13 | |
2017-02-15 | c-user: Document linker set content | Sebastian Huber | 1 | -0/+48 | |
Close #2770. | |||||
2017-02-14 | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 3 | -44/+40 | |
Update #2894. | |||||
2017-02-03 | c-user: Add SMP internal locking | Sebastian Huber | 1 | -0/+38 | |
2017-02-03 | c-user: Add SMP profiling | Sebastian Huber | 1 | -0/+58 | |
2017-02-03 | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2 | -3/+2 | |
Update #2893. | |||||
2017-02-03 | c-user: Update SMP introduction | Sebastian Huber | 3 | -50/+48 | |
2017-02-03 | c-user: New SMP chapter title | Sebastian Huber | 1 | -2/+2 | |
2017-02-03 | c-user: Add TAS and TTAS terms | Sebastian Huber | 2 | -2/+8 | |
2017-02-03 | c-user: Update scheduler helping protocol | Sebastian Huber | 1 | -68/+50 | |
2017-02-02 | c-user: Add SMP low-level synchronization | Sebastian Huber | 2 | -41/+93 | |
2017-02-02 | c-user: Use sphinx glossary support | Sebastian Huber | 2 | -658/+658 | |
Terms can be referenced via :term:`XYZ`. | |||||
2017-02-02 | c-user: Add SMP implementation details section | Sebastian Huber | 1 | -38/+41 | |
2017-02-02 | c-user: Add SMP application issues section | Sebastian Huber | 2 | -151/+209 | |
2017-02-02 | c-user: Update clustered scheduling | Sebastian Huber | 1 | -21/+45 | |
2017-02-01 | Use "in X config..." instead of "on X config..." | Sebastian Huber | 6 | -28/+27 | |
2017-02-01 | c-user: Move scheduler directives | Sebastian Huber | 2 | -166/+175 | |
2017-02-01 | c-user: Remove duplicate thread queue section | Sebastian Huber | 1 | -50/+0 | |
2017-02-01 | c-user: Update task migration | Sebastian Huber | 1 | -29/+9 | |
2017-02-01 | c-user: Move some task directives | Sebastian Huber | 2 | -237/+234 | |
2017-02-01 | c-user: Add Key concept locking protocols | Sebastian Huber | 2 | -85/+124 | |
Update #2412. Update #2556. | |||||
2017-02-01 | c-user: Add key concept thread queues | Sebastian Huber | 2 | -2/+70 | |
2017-01-31 | Fix refs.bib entry | Sebastian Huber | 1 | -1/+1 | |
2017-01-31 | c-user: Task names | Sebastian Huber | 2 | -1/+15 | |
Update #2858. | |||||
2017-01-30 | c-user: Update initialization | Sebastian Huber | 1 | -4/+4 | |
Update #2692. | |||||
2017-01-30 | c-user: Update timer manager | Sebastian Huber | 1 | -8/+16 | |
Update #2554. | |||||
2017-01-30 | c-user: Add timer and timeouts key concept | Sebastian Huber | 2 | -1/+41 | |
2017-01-30 | c-user: Update key concepts time | Sebastian Huber | 2 | -11/+14 | |
2017-01-30 | c-user: Update overrun handling related functions and structure | Kuan-Hsun Chen | 1 | -34/+23 | |
State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795. | |||||
2017-01-27 | c-user: Clarify rtems_heap_extend() | Sebastian Huber | 1 | -9/+11 | |
Update #1747. | |||||
2017-01-27 | c-user: Region directives use the allocator mutex | Sebastian Huber | 1 | -3/+12 | |
2017-01-27 | c-user: Fix region directive prototypes | Sebastian Huber | 1 | -26/+26 | |
2017-01-26 | c-user: Rework user extensions chapter | Sebastian Huber | 3 | -306/+286 | |
Update #2692. Update #2752. | |||||
2017-01-24 | c-user: SMP thread dispatching | Sebastian Huber | 1 | -57/+23 | |
Close #2809. | |||||
2017-01-23 | c-user: Clarify simple binary semaphore release | Sebastian Huber | 1 | -9/+11 | |
Close #2725. | |||||
2017-01-19 | c-user/ada_support.rst: Discuss timer server and interrupt threads | Joel Sherrill | 1 | -0/+7 | |
2017-01-18 | c-user: Add support for references via bibtex | Sebastian Huber | 4 | -9/+13 | |
https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
2017-01-17 | c-user: Add Ada support chapter | Joel Sherrill | 2 | -0/+93 | |
closes #2589. | |||||
2017-01-17 | c-user: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2017-01-13 | Update documentation to reflect EDF scheduler overrun handling | Kuan-Hsun Chen | 1 | -12/+16 | |
2017-01-13 | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 1 | -0/+31 | |
2017-01-11 | Update document titles for consistency | Joel Sherrill | 2 | -7/+7 | |
2016-12-21 | Update version/revision to 4.11.99 | Sebastian Huber | 1 | -2/+2 | |
2016-12-19 | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 1 | -32/+0 | |
Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | |||||
2016-12-19 | Do not mention obsolete Giant lock | Sebastian Huber | 1 | -5/+0 | |
Close #2555. | |||||
2016-12-19 | Update rtems_interrupt_frame description | Sebastian Huber | 1 | -1/+2 | |
Close #2808. |
