* | c-user: Add Local vs Global to Key Concepts Chapter | Joel Sherrill | 2022-12-07 | 1 | -8/+68 |
| | | | | | | | Add multiple new index entries and cite them where RTEMS_LOCAL and RTEMS_GLOBAL are cited. Closes #4453. | ||||
* | Document CONFIGURE_RECORD_INTERRUPTS_ENABLED | Sebastian Huber | 2022-12-02 | 1 | -1/+42 |
| | | | | Close #4769. | ||||
* | c-user/*: Add trailing parentheses on methods in index which were missing it | Joel Sherrill | 2022-11-30 | 11 | -71/+71 |
| | | | | Closes #4766. | ||||
* | c-user: Adjust URL for struct timespec | Sebastian Huber | 2022-11-08 | 1 | -5/+4 |
* | c-user/clock: Fix typo | Matt Joyce | 2022-11-08 | 1 | -1/+1 |
* | c-user: INTERNAL_ERROR_IDLE_THREAD_STACK_TOO_SMALL | Sebastian Huber | 2022-10-14 | 1 | -0/+7 |
| | | | | Document this fatal error. | ||||
* | c-user: INTERNAL_ERROR_NO_MEMORY_FOR_IDLE_TASK_STORAGE | Sebastian Huber | 2022-10-14 | 1 | -0/+5 |
* | c-user: INTERNAL_ERROR_IDLE_THREAD_CREATE_FAILED | Sebastian Huber | 2022-10-14 | 1 | -0/+5 |
* | c-user: Add CONFIGURE_IDLE_TASK_STORAGE_SIZE | Sebastian Huber | 2022-10-14 | 2 | -11/+101 |
* | c-user: Fix references | Sebastian Huber | 2022-10-06 | 1 | -10/+5 |
* | c-user: INTERNAL_ERROR_RTEMS_INIT_TASK_CONSTRUCT_FAILED | Sebastian Huber | 2022-10-06 | 1 | -3/+8 |
* | c-user: CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE | Sebastian Huber | 2022-10-06 | 2 | -63/+63 |
| | | | | | Move CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE to the general configuration options. | ||||
* | c-user: Add application config info directives | Sebastian Huber | 2022-10-04 | 13 | -96/+1832 |
| | | | | | Close #4267. Close #4269. | ||||
* | c-user: Add types to macros | Sebastian Huber | 2022-10-04 | 4 | -22/+44 |
* | c-user: Add type roles | Sebastian Huber | 2022-09-29 | 1 | -6/+6 |
* | c-user/config/face.rst: New file -- add CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR | Joel Sherrill | 2022-09-05 | 2 | -0/+77 |
| | | | | Closes #4691. | ||||
* | c-user: Clarify BSP related configuration settings | Sebastian Huber | 2022-08-31 | 3 | -9/+76 |
* | c-user: Update OAR copyright and reformat | Sebastian Huber | 2022-08-11 | 3 | -14/+10 |
| | | | | These files are generated by a script. | ||||
* | c-user: Document new rtems_task_delete() behaviour | Sebastian Huber | 2022-07-28 | 1 | -5/+20 |
| | | | | Update #4679. | ||||
* | c-user: Document task life states | Sebastian Huber | 2022-07-28 | 1 | -1/+53 |
* | c-user: Do not mention pseudo-interrupt priority | Sebastian Huber | 2022-07-26 | 2 | -3/+4 |
| | | | | Update #2365. | ||||
* | c-user: Update references to --enable-* configure options. | Joel Sherrill | 2022-05-20 | 4 | -30/+44 |
| | | | | | Also updated list of SMP architectures and added enough lead in to let users know the source code was the definitive answer. | ||||
* | c-user: Clarify scheduler of created task | Sebastian Huber | 2022-03-30 | 1 | -3/+3 |
* | c-user: Improve interrupt set affinity handling | Sebastian Huber | 2022-03-16 | 2 | -2/+7 |
| | | | | Update #3269. | ||||
* | c-user: Document CONFIGURE_SCHEDULER_TABLE_ENTRIES | Sebastian Huber | 2022-02-22 | 1 | -3/+90 |
| | | | | Update #4524. | ||||
* | c-user: Use document internal links | Sebastian Huber | 2022-01-11 | 1 | -10/+12 |
* | c-user: Clarify Clock Manager dependencies | Sebastian Huber | 2022-01-11 | 1 | -8/+16 |
| | | | | Update #4572. | ||||
* | c-user: Clarify time formats | Sebastian Huber | 2021-12-16 | 1 | -12/+27 |
* | c-user: Fix Clock Manager parameter descriptions | Sebastian Huber | 2021-12-16 | 1 | -17/+21 |
* | c-user: Replace "precision" with "resolution" | Sebastian Huber | 2021-11-23 | 2 | -33/+33 |
| | | | | Resolution is the right term for the documented property. | ||||
* | c-user: rtems_scheduler_remove_processor() | Sebastian Huber | 2021-11-19 | 1 | -3/+6 |
| | | | | | | Update error status description. Close #4544. | ||||
* | c-user: Document new clock manager directives | Sebastian Huber | 2021-11-19 | 2 | -0/+916 |
| | | | | | | | Add new clock manager directives to get all times provided by the timehands. Close #4527. | ||||
* | c-user: Use RTEMS_WHO_AM_I for rtems_task_ident() | Sebastian Huber | 2021-11-19 | 1 | -2/+2 |
* | c-user: Use rubric for configuration options | Sebastian Huber | 2021-11-17 | 14 | -3029/+4307 |
| | | | | | | | | | | | | | Clear the page for each configuration options similar to the directives. Use a rubric instead of a definition list for the application configuration options similar to the directive documentation pages. For direcives and application configuration options use the same rubric order. Generalize value constraints to constraints. This patch does not change hand written content. | ||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 2021-11-16 | 1 | -2/+2 |
| | | | | Fix default value description. | ||||
* | c-user: Update for application CONFIGURE option | Kinsey Moore | 2021-11-03 | 1 | -0/+30 |
| | | | | | This adds the documentation for the application configuration option CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING. | ||||
* | c-user: rtems_rate_monotonic_get_status() | Sebastian Huber | 2021-10-25 | 1 | -4/+5 |
| | | | | | | | | | Mention that resetting the processor usage time of tasks has no impact on the period status and statistics. Remove no longer relevant RTEMS_NOT_DEFINED error status. Close #4528. | ||||
* | c-user: Regenerate for IDLE task allocator option | Sebastian Huber | 2021-10-25 | 1 | -34/+37 |
* | task-stack-alloc.rst: Add CONFIGURE_TASK_STACK_FROM_ALLOCATOR | Joel Sherrill | 2021-10-12 | 1 | -0/+33 |
| | | | | Updates #4524. | ||||
* | glossary: Add terms | Sebastian Huber | 2021-09-30 | 1 | -0/+30 |
* | glossary: Add OMIP | Sebastian Huber | 2021-09-28 | 1 | -0/+6 |
* | rtems: Fix message manager documentation | Sebastian Huber | 2021-09-16 | 1 | -2/+2 |
| | | | | | | | Correct the description of the ``count`` parameter of rtems_message_queue_flush(). Close #4508. | ||||
* | c-user: Fix use of lower and higher priority | Sebastian Huber | 2021-09-15 | 1 | -2/+2 |
* | c-user: Clarify task priorities | Sebastian Huber | 2021-09-15 | 3 | -12/+16 |
* | c-user: Define lower and higher priority | Sebastian Huber | 2021-09-15 | 1 | -5/+32 |
* | c-user: Fix message manager documentation | Sebastian Huber | 2021-09-15 | 1 | -9/+10 |
| | | | | | | | Remove bogus return status from rtems_message_queue_receive(). Clarify rtems_message_queue_flush(). Close #4508. | ||||
* | c-user: Clarify rtems_extension_create() | Sebastian Huber | 2021-09-15 | 1 | -3/+7 |
* | c-user: Add "Cache Manager" chapter | Sebastian Huber | 2021-09-13 | 4 | -0/+782 |
| | | | | | | | | | | | | | | | | | | | | | | The Cache Manager directives are available via <rtems.h>. Document most of them in the Classic API Guide. Not documented are the following directive since the API is not yet stable: * rtems_cache_coherent_allocate() * rtems_cache_coherent_free() * rtems_cache_coherent_add_area() Not documented are the following directive since the directives are not implemented on maintained platforms: * rtems_cache_freeze_data() * rtems_cache_freeze_instruction() * rtems_cache_unfreeze_data() * rtems_cache_unfreeze_instruction() Close #4513. | ||||
* | c-user: Document time of day constraints | Sebastian Huber | 2021-09-06 | 1 | -4/+15 |
| | | | | Close #4338. | ||||
* | c-user: Add LIFO to glossary | Sebastian Huber | 2021-09-02 | 1 | -1/+9 |
