* | fix typo: extesion->extension | Malte Münch | 2018-05-18 | 1 | -1/+1 | |
* | c-user: Update manual organization in overview | Malte Münch | 2018-05-18 | 1 | -32/+57 | |
* | c-user: Fix reference | Sebastian Huber | 2018-04-30 | 1 | -6/+6 | |
* | c-user: Fix typo | Sebastian Huber | 2018-04-30 | 1 | -2/+2 | |
* | c-user: Properly fix the previous typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 | |
* | c-user: Fix typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 | |
* | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 1 | -45/+54 | |
| | | | | Close #3325. | |||||
* | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 2018-03-09 | 1 | -1/+1 | |
* | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 2018-03-08 | 1 | -78/+92 | |
| | | | | Update #3325. | |||||
* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 2 | -151/+185 | |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 7 | -25/+25 | |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 | |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 3 | -8/+7 | |
| | | | | Add own section for the clustered scheduler configuration. | |||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 2 | -4/+6 | |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 2 | -9/+27 | |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 | |
| | | | | Update #3320. | |||||
* | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 2018-02-05 | 1 | -0/+39 | |
| | | | | | Close #3170. Update #3199. | |||||
* | c-user: Fix index directives | Sebastian Huber | 2018-02-05 | 1 | -0/+10 | |
| | | | | Update #3229. | |||||
* | c-user: Use configuration option as section name | Sebastian Huber | 2018-02-05 | 1 | -713/+390 | |
| | | | | | | | This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | |||||
* | c-user: Document obsolete termios config options | Sebastian Huber | 2018-02-05 | 1 | -63/+16 | |
| | | | | Update #2843. | |||||
* | c-user: Add self-contained objects chapter | Sebastian Huber | 2018-02-05 | 2 | -0/+1071 | |
* | c-user: Clarify user extensions | Sebastian Huber | 2018-01-05 | 1 | -10/+16 | |
* | c-user: Update unlimites objects configuration | Sebastian Huber | 2017-12-15 | 1 | -33/+22 | |
* | Account for non-preemption and interrupt level not supported on SMP | Joel Sherrill | 2017-12-06 | 2 | -1/+9 | |
| | | | | Closes #3000. | |||||
* | c-user: Clarify local interrupt disable | Sebastian Huber | 2017-12-01 | 1 | -3/+6 | |
* | c-user: Clarify interrupt manager directives | Sebastian Huber | 2017-11-30 | 1 | -58/+137 | |
| | | | | Use RTEMS coding style in all code blocks. | |||||
* | c-user: Document global construction | Sebastian Huber | 2017-11-24 | 2 | -5/+74 | |
| | | | | Close #3243. | |||||
* | c-user: Document rtems_panic() | Sebastian Huber | 2017-11-23 | 1 | -4/+42 | |
| | | | | Close #3244. | |||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_RWLOCK | Sebastian Huber | 2017-11-22 | 1 | -4/+0 | |
| | | | | Update #3115. | |||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_BARRIER | Sebastian Huber | 2017-11-22 | 1 | -4/+0 | |
| | | | | Update #3114. | |||||
* | c-user: Remove RTEMS_SYSINIT_POSIX_MUTEX | Sebastian Huber | 2017-11-22 | 1 | -4/+0 | |
| | | | | Update #3112. | |||||
* | c-user: RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE | Sebastian Huber | 2017-11-22 | 1 | -4/+0 | |
| | | | | Update #3113. | |||||
* | Mention barrier manager in rtems_semaphore_flush() | Sebastian Huber | 2017-11-20 | 2 | -0/+6 | |
* | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-20 | 1 | -1/+2 | |
| | | | | Update #3239. | |||||
* | c-user: Clarify rtems_interrupt_flash() | Sebastian Huber | 2017-11-20 | 1 | -7/+11 | |
* | c-user: Remove clock driver specific functions | Sebastian Huber | 2017-11-17 | 1 | -3/+0 | |
| | | | | | | Do not mention functions which belong to a specific clock driver implementation. These functions should not be called by applications directly. | |||||
* | Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 2017-11-17 | 1 | -0/+4 | |
| | | | | Close #3239. | |||||
* | INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT | Sebastian Huber | 2017-11-17 | 1 | -0/+4 | |
* | c-users: Clarify semaphore obtain/flush | Sebastian Huber | 2017-11-16 | 1 | -1/+43 | |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 29 | -345/+665 | |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 36 | -785/+920 | |
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 | |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 4 | -36/+36 | |
| | | | | Update #3220. | |||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 | |
| | | | | closes #3215. | |||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 | |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | |||||
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 2 | -95/+22 | |
| | | | | Closes #2693. | |||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 | |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | |||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 | |
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 | |
* | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 2017-09-14 | 1 | -1/+4 | |
