2018-08-21 | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2 | -5/+1 | |
- Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | |||||
2018-08-11 | c-user: SMP is supported on RISC-V | Sebastian Huber | 1 | -1/+3 | |
Update #3433. | |||||
2018-08-10 | c-user: Adjust integer types in partition create | Sebastian Huber | 1 | -2/+2 | |
Close #3486. | |||||
2018-08-07 | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 1 | -7/+37 | |
Close #3434. | |||||
2018-08-07 | c-user: Sort POSIX configuration options | Sebastian Huber | 1 | -60/+60 | |
2018-08-03 | c-user: Update partition create documentation | Sebastian Huber | 1 | -11/+54 | |
Add an example. Close #3482. | |||||
2018-06-19 | c-user: Document RTEMS_SYSINIT_CPU_COUNTER | Sebastian Huber | 1 | -0/+6 | |
Update #3456. | |||||
2018-06-18 | c-user: Remove obsolete RTEMS_SYSINIT_CPU_SET | Sebastian Huber | 1 | -4/+0 | |
Update #2514. | |||||
2018-06-05 | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 1 | -0/+4 | |
Close #3437. | |||||
2018-06-05 | c-user: Update rtems_region_create() | Sebastian Huber | 1 | -9/+10 | |
2018-05-23 | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2 | -2/+2 | |
2018-05-20 | c-user: changed RTEMS_STATUS_SUCCESSFUL to RTEMS_SUCCESSFUL | Malte Münch | 1 | -2/+2 | |
2018-05-18 | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 1 | -1/+1 | |
2018-05-18 | fix typo: extesion->extension | Malte Münch | 1 | -1/+1 | |
2018-05-18 | c-user: Update manual organization in overview | Malte Münch | 1 | -32/+57 | |
2018-04-30 | c-user: Fix reference | Sebastian Huber | 1 | -6/+6 | |
2018-04-30 | c-user: Fix typo | Sebastian Huber | 1 | -2/+2 | |
2018-03-12 | c-user: Properly fix the previous typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2018-03-12 | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 1 | -45/+54 | |
Close #3325. | |||||
2018-03-09 | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 1 | -1/+1 | |
2018-03-08 | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 1 | -78/+92 | |
Update #3325. | |||||
2018-03-07 | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2 | -151/+185 | |
2018-03-07 | c-user: Use uniprocessor throughout | Sebastian Huber | 7 | -25/+25 | |
2018-03-07 | c-user: Sort scheduler configuration options | Sebastian Huber | 1 | -96/+96 | |
2018-03-07 | c-user: Promote clustered scheduler configuration | Sebastian Huber | 3 | -8/+7 | |
Add own section for the clustered scheduler configuration. | |||||
2018-03-07 | c-user: Fix scheduler configuration overview | Sebastian Huber | 2 | -4/+6 | |
2018-03-07 | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2 | -9/+27 | |
2018-03-06 | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 1 | -13/+84 | |
Update #3320. | |||||
2018-02-05 | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER | Sebastian Huber | 1 | -0/+39 | |
Close #3170. Update #3199. | |||||
2018-02-05 | c-user: Fix index directives | Sebastian Huber | 1 | -0/+10 | |
Update #3229. | |||||
2018-02-05 | c-user: Use configuration option as section name | Sebastian Huber | 1 | -713/+390 | |
This makes it easier to find the documentation for a given configuration option. Remove superfluous comments. | |||||
2018-02-05 | c-user: Document obsolete termios config options | Sebastian Huber | 1 | -63/+16 | |
Update #2843. | |||||
2018-02-05 | c-user: Add self-contained objects chapter | Sebastian Huber | 2 | -0/+1071 | |
2018-01-05 | c-user: Clarify user extensions | Sebastian Huber | 1 | -10/+16 | |
2017-12-15 | c-user: Update unlimites objects configuration | Sebastian Huber | 1 | -33/+22 | |
2017-12-06 | Account for non-preemption and interrupt level not supported on SMP | Joel Sherrill | 2 | -1/+9 | |
Closes #3000. | |||||
2017-12-01 | c-user: Clarify local interrupt disable | Sebastian Huber | 1 | -3/+6 | |
2017-11-30 | c-user: Clarify interrupt manager directives | Sebastian Huber | 1 | -58/+137 | |
Use RTEMS coding style in all code blocks. | |||||
2017-11-24 | c-user: Document global construction | Sebastian Huber | 2 | -5/+74 | |
Close #3243. | |||||
2017-11-23 | c-user: Document rtems_panic() | Sebastian Huber | 1 | -4/+42 | |
Close #3244. | |||||
2017-11-22 | c-user: Remove RTEMS_SYSINIT_POSIX_RWLOCK | Sebastian Huber | 1 | -4/+0 | |
Update #3115. | |||||
2017-11-22 | c-user: Remove RTEMS_SYSINIT_POSIX_BARRIER | Sebastian Huber | 1 | -4/+0 | |
Update #3114. | |||||
2017-11-22 | c-user: Remove RTEMS_SYSINIT_POSIX_MUTEX | Sebastian Huber | 1 | -4/+0 | |
Update #3112. | |||||
2017-11-22 | c-user: RTEMS_SYSINIT_POSIX_CONDITION_VARIABLE | Sebastian Huber | 1 | -4/+0 | |
Update #3113. | |||||
2017-11-20 | Mention barrier manager in rtems_semaphore_flush() | Sebastian Huber | 2 | -0/+6 | |
2017-11-20 | Clarify INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 1 | -1/+2 | |
Update #3239. | |||||
2017-11-20 | c-user: Clarify rtems_interrupt_flash() | Sebastian Huber | 1 | -7/+11 | |
2017-11-17 | c-user: Remove clock driver specific functions | Sebastian Huber | 1 | -3/+0 | |
Do not mention functions which belong to a specific clock driver implementation. These functions should not be called by applications directly. | |||||
2017-11-17 | Document INTERNAL_ERROR_ARC4RANDOM_GETENTROPY_FAIL | Sebastian Huber | 1 | -0/+4 | |
Close #3239. |
