* | INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT | Sebastian Huber | 2017-11-17 | 1 | -0/+4 | |
* | c-users: Clarify semaphore obtain/flush | Sebastian Huber | 2017-11-16 | 1 | -1/+43 | |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 29 | -345/+665 | |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 36 | -785/+920 | |
* | Add indexes to all documents. | Chris Johns | 2017-11-12 | 2 | -2/+5 | |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 4 | -36/+36 | |
| | | | | Update #3220. | |||||
* | c-user/configuring_a_system.rst: Delete notepads section | Joel Sherrill | 2017-11-02 | 1 | -32/+0 | |
| | | | | closes #3215. | |||||
* | c-user: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES | Sebastian Huber | 2017-10-12 | 1 | -6/+30 | |
| | | | | | | | This configuration is not obsolete since it is still used for named semaphores. Update #3116. | |||||
* | c-user: Update to reflect rtems_clock_get() being obsoleted. | Joel Sherrill | 2017-10-11 | 2 | -95/+22 | |
| | | | | Closes #2693. | |||||
* | c-user: Add obsolete configuration options section | Sebastian Huber | 2017-10-09 | 1 | -164/+88 | |
| | | | | | | | | | Update #2493. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | |||||
* | c-user: Clarify that confdefs.h is mandatory | Sebastian Huber | 2017-10-06 | 1 | -21/+3 | |
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 | |
* | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 2017-09-14 | 1 | -1/+4 | |
* | c-user: Clarify user extensions | Sebastian Huber | 2017-08-24 | 1 | -59/+66 | |
| | | | | Close #2367. | |||||
* | Update copyright notices. | Chris Johns | 2017-08-11 | 1 | -4/+7 | |
* | c-user: Fix interrupt lock documentation | Sebastian Huber | 2017-07-14 | 1 | -17/+35 | |
| | | | | Update #3075. | |||||
* | c-user: Document new scheduler ident routines | Sebastian Huber | 2017-07-12 | 1 | -0/+83 | |
| | | | | | Close #3069. Close #3070. | |||||
* | c-user: Update scheduler/task chapter | Sebastian Huber | 2017-07-10 | 2 | -34/+87 | |
| | | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063. | |||||
* | c-user: Document EDF SMP | Sebastian Huber | 2017-06-30 | 2 | -0/+34 | |
| | | | | Close #3056. | |||||
* | c-user: Replace pre-emption with preemption | Sebastian Huber | 2017-05-11 | 2 | -8/+8 | |
* | c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulas | Joel Sherrill | 2017-04-25 | 1 | -9/+8 | |
* | waf: Cleaner formatting to see the importing. | Chris Johns | 2017-03-27 | 1 | -2/+7 | |
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -4/+5 | |
* | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 2017-03-08 | 1 | -1/+3 | |
* | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 2017-03-07 | 1 | -31/+39 | |
* | Move extensions to common conf.py | Sebastian Huber | 2017-02-22 | 1 | -2/+0 | |
* | Render math via JavaScript in HTML output | Sebastian Huber | 2017-02-20 | 1 | -1/+1 | |
* | c-user: Fix linker set code blocks | Sebastian Huber | 2017-02-15 | 1 | -12/+13 | |
* | c-user: Document linker set content | Sebastian Huber | 2017-02-15 | 1 | -0/+48 | |
| | | | | Close #2770. | |||||
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 3 | -44/+40 | |
| | | | | Update #2894. | |||||
* | c-user: Add SMP internal locking | Sebastian Huber | 2017-02-03 | 1 | -0/+38 | |
* | c-user: Add SMP profiling | Sebastian Huber | 2017-02-03 | 1 | -0/+58 | |
* | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-03 | 2 | -3/+2 | |
| | | | | Update #2893. | |||||
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 3 | -50/+48 | |
* | c-user: New SMP chapter title | Sebastian Huber | 2017-02-03 | 1 | -2/+2 | |
* | c-user: Add TAS and TTAS terms | Sebastian Huber | 2017-02-03 | 2 | -2/+8 | |
* | c-user: Update scheduler helping protocol | Sebastian Huber | 2017-02-03 | 1 | -68/+50 | |
* | c-user: Add SMP low-level synchronization | Sebastian Huber | 2017-02-02 | 2 | -41/+93 | |
* | c-user: Use sphinx glossary support | Sebastian Huber | 2017-02-02 | 2 | -658/+658 | |
| | | | | Terms can be referenced via :term:`XYZ`. | |||||
* | c-user: Add SMP implementation details section | Sebastian Huber | 2017-02-02 | 1 | -38/+41 | |
* | c-user: Add SMP application issues section | Sebastian Huber | 2017-02-02 | 2 | -151/+209 | |
* | c-user: Update clustered scheduling | Sebastian Huber | 2017-02-02 | 1 | -21/+45 | |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 6 | -28/+27 | |
* | c-user: Move scheduler directives | Sebastian Huber | 2017-02-01 | 2 | -166/+175 | |
* | c-user: Remove duplicate thread queue section | Sebastian Huber | 2017-02-01 | 1 | -50/+0 | |
* | c-user: Update task migration | Sebastian Huber | 2017-02-01 | 1 | -29/+9 | |
* | c-user: Move some task directives | Sebastian Huber | 2017-02-01 | 2 | -237/+234 | |
* | c-user: Add Key concept locking protocols | Sebastian Huber | 2017-02-01 | 2 | -85/+124 | |
| | | | | | Update #2412. Update #2556. | |||||
* | c-user: Add key concept thread queues | Sebastian Huber | 2017-02-01 | 2 | -2/+70 | |
* | Fix refs.bib entry | Sebastian Huber | 2017-01-31 | 1 | -1/+1 | |
