path: root/c-user (follow)
* c-user: Clarify user extensionsSebastian Huber2017-08-241-59/+66
| | | | Close #2367.
* Update copyright notices.Chris Johns2017-08-111-4/+7
* c-user: Fix interrupt lock documentationSebastian Huber2017-07-141-17/+35
| | | | Update #3075.
* c-user: Document new scheduler ident routinesSebastian Huber2017-07-121-0/+83
| | | | | Close #3069. Close #3070.
* c-user: Update scheduler/task chapterSebastian Huber2017-07-102-34/+87
| | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063.
* c-user: Document EDF SMPSebastian Huber2017-06-302-0/+34
| | | | Close #3056.
* c-user: Replace pre-emption with preemptionSebastian Huber2017-05-112-8/+8
* c-user/rate_monotonic_manager.rst: Use Latex math for utilization formulasJoel Sherrill2017-04-251-9/+8
* waf: Cleaner formatting to see the importing.Chris Johns2017-03-271-2/+7
* Use a single top level version number.Chris Johns2017-03-201-4/+5
* c-user: Add note to rtems_task_set_scheduler()Sebastian Huber2017-03-081-1/+3
* c-user: Update rtems_task_set_scheduler()Sebastian Huber2017-03-071-31/+39
* Move extensions to common conf.pySebastian Huber2017-02-221-2/+0
* Render math via JavaScript in HTML outputSebastian Huber2017-02-201-1/+1
* c-user: Fix linker set code blocksSebastian Huber2017-02-151-12/+13
* c-user: Document linker set contentSebastian Huber2017-02-151-0/+48
| | | | Close #2770.
* c-user: CONFIGURE_MAXIMUM_PROCESSORSSebastian Huber2017-02-143-44/+40
| | | | Update #2894.
* c-user: Add SMP internal lockingSebastian Huber2017-02-031-0/+38
* c-user: Add SMP profilingSebastian Huber2017-02-031-0/+58
* c-user: Eliminate CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-032-3/+2
| | | | Update #2893.
* c-user: Update SMP introductionSebastian Huber2017-02-033-50/+48
* c-user: New SMP chapter titleSebastian Huber2017-02-031-2/+2
* c-user: Add TAS and TTAS termsSebastian Huber2017-02-032-2/+8
* c-user: Update scheduler helping protocolSebastian Huber2017-02-031-68/+50
* c-user: Add SMP low-level synchronizationSebastian Huber2017-02-022-41/+93
* c-user: Use sphinx glossary supportSebastian Huber2017-02-022-658/+658
| | | | Terms can be referenced via :term:`XYZ`.
* c-user: Add SMP implementation details sectionSebastian Huber2017-02-021-38/+41
* c-user: Add SMP application issues sectionSebastian Huber2017-02-022-151/+209
* c-user: Update clustered schedulingSebastian Huber2017-02-021-21/+45
* Use "in X config..." instead of "on X config..."Sebastian Huber2017-02-016-28/+27
* c-user: Move scheduler directivesSebastian Huber2017-02-012-166/+175
* c-user: Remove duplicate thread queue sectionSebastian Huber2017-02-011-50/+0
* c-user: Update task migrationSebastian Huber2017-02-011-29/+9
* c-user: Move some task directivesSebastian Huber2017-02-012-237/+234
* c-user: Add Key concept locking protocolsSebastian Huber2017-02-012-85/+124
| | | | | Update #2412. Update #2556.
* c-user: Add key concept thread queuesSebastian Huber2017-02-012-2/+70
| | | | Update #2556.
* Fix refs.bib entrySebastian Huber2017-01-311-1/+1
* c-user: Task namesSebastian Huber2017-01-312-1/+15
| | | | Update #2858.
* c-user: Update initializationSebastian Huber2017-01-301-4/+4
| | | | Update #2692.
* c-user: Update timer managerSebastian Huber2017-01-301-8/+16
| | | | Update #2554.
* c-user: Add timer and timeouts key conceptSebastian Huber2017-01-302-1/+41
| | | | Update #2554.
* c-user: Update key concepts timeSebastian Huber2017-01-302-11/+14
* c-user: Update overrun handling related functions and structureKuan-Hsun Chen2017-01-301-34/+23
| | | | | | | | | State the limited count of postponed_jobs. Update _rtems_rate_monotonic_get_status() and related structure. Move "Further Reading" in c-user to references. Add mentioned papers in ticket #2795 to references. Update #2795.
* c-user: Clarify rtems_heap_extend()Sebastian Huber2017-01-271-9/+11
| | | | Update #1747.
* c-user: Region directives use the allocator mutexSebastian Huber2017-01-271-3/+12
* c-user: Fix region directive prototypesSebastian Huber2017-01-271-26/+26
* c-user: Rework user extensions chapterSebastian Huber2017-01-263-306/+286
| | | | | Update #2692. Update #2752.
* c-user: SMP thread dispatchingSebastian Huber2017-01-241-57/+23
| | | | Close #2809.
* c-user: Clarify simple binary semaphore releaseSebastian Huber2017-01-231-9/+11
| | | | Close #2725.
* c-user/ada_support.rst: Discuss timer server and interrupt threadsJoel Sherrill2017-01-191-0/+7
