* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 4 | -9/+13 | |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
* | c-user: Add Ada support chapter | Joel Sherrill | 2017-01-17 | 2 | -0/+93 | |
| | | | | closes #2589. | |||||
* | c-user: Fix typo | Sebastian Huber | 2017-01-17 | 1 | -1/+1 | |
* | Update documentation to reflect EDF scheduler overrun handling | Kuan-Hsun Chen | 2017-01-13 | 1 | -12/+16 | |
| | | | | Update #2795. | |||||
* | Document CONFIGURE_MAXIMUM_THREAD_NAME_SIZE | Sebastian Huber | 2017-01-13 | 1 | -0/+31 | |
| | | | | Update #2858. | |||||
* | Update document titles for consistency | Joel Sherrill | 2017-01-11 | 2 | -7/+7 | |
* | Update version/revision to 4.11.99 | Sebastian Huber | 2016-12-21 | 1 | -2/+2 | |
* | CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS | Sebastian Huber | 2016-12-19 | 1 | -32/+0 | |
| | | | | | | | Do not mention obsolete CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS. Close #2702. | |||||
* | Do not mention obsolete Giant lock | Sebastian Huber | 2016-12-19 | 1 | -5/+0 | |
| | | | | Close #2555. | |||||
* | Update rtems_interrupt_frame description | Sebastian Huber | 2016-12-19 | 1 | -1/+2 | |
| | | | | Close #2808. | |||||
* | Document rtems_task_get_priority() | Sebastian Huber | 2016-12-19 | 1 | -0/+51 | |
| | | | | Close #2784. | |||||
* | Update Task Manager chapter | Sebastian Huber | 2016-12-13 | 1 | -184/+180 | |
| | | | | | | Introduce "Deprecated and Removed Directives" section. Update #2423. | |||||
* | Update Initialization Manager chapter | Sebastian Huber | 2016-12-12 | 3 | -100/+226 | |
| | | | | Update #2408. | |||||
* | Improve fatal error chapter | Sebastian Huber | 2016-12-12 | 3 | -64/+117 | |
| | | | | Update #2825. | |||||
* | Update linker set documentation | Sebastian Huber | 2016-12-06 | 1 | -2/+93 | |
| | | | | | Update #2408. Update #2790. | |||||
* | Improve fatal error chapter | Sebastian Huber | 2016-11-23 | 1 | -56/+120 | |
* | Rework fatal error chapter | Sebastian Huber | 2016-11-21 | 1 | -85/+267 | |
| | | | | Update #2811. | |||||
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 2 | -33/+125 | |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 38 | -57/+55 | |
* | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 2016-11-08 | 2 | -4/+5 | |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 30 | -8135/+7796 | |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 7 | -109/+28 | |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 41 | -0/+24958 | |
