The manager documentation is a consolidation of the comments in Doxygen
markup and the documentation sources in Sphinx markup. The
documentation was transfered to interface specification items. This
header file was generated from the items by a script.
Update #3993.
Document this application configuration option.
Update #3959.
Close #4074.
Introduce a background section.
This makes it easier to automatically generate parts of the scheduling
concepts documentation in the future.
Update #3993.
This makes it easier to automatically generate parts of the manager
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3993.
Update #3994.
The formatting is generated through references within the specification.
Update #3994.
Improve formatting.
This is a prepration step to allow the generation of the application
configuration options in Doxygen markup.
Some objects can be created with a local or global scope in a
multiprocessing network. In non-multiprocessing configurations setting
the scope to local or global had no effect since such a system can be
viewed as a multiprocessing network with just one node. One and all
nodes is the same in such a network. However, if multiprocessing was
configured, creation of a global object in a single node network
resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error
condition for symmetry to the non-multiprocessing setup. This is in line
with the task affinity behaviour in SMP systems.
Close #4005.
Mention that object create/delete may case the calling task to be
preempted due to the object allocator mutex.
Close #3953.
Update #3815.
Be in line with Task Manager chapter.
Update #2693.
Start with templates for the application configuration options.
Remove "Format to be followed for making changes in this file" from
c-user.
Update #3910.
Move this option to the scheduler configuration options.
Update #3836.
Update #3836.
Define the following terms:
* assembler language
* C language
* ELF
* interrupt service
* software component
* software unit
Clarify:
* task
Update #3715.
Close #2806.
Try to bring all descriptions up to date. Add cross-references to
several options. Clarify configuration value constraints.
Use this template also for initializer type options.
Close #3901.
Update #3900.
Update #3900.
Update #3836.
Update #3904.
several options.
Close #3900.
