* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 39 | -39/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 39 | -74/+41 |
* | Add common header.rst to reduce copy and paste | Sebastian Huber | 2019-01-09 | 1 | -23/+1 |
* | c-user: Fix typos | Frédéric Jouault | 2019-01-04 | 2 | -4/+4 |
| | | | | Close #3261. | ||||
* | c-user: rtems_scheduler_get_maximum_priority() | Sebastian Huber | 2018-12-10 | 1 | -0/+37 |
| | | | | Close #3636. | ||||
* | c-user: Remove 16-bit object identifiers | Sebastian Huber | 2018-11-21 | 1 | -36/+8 |
| | | | | Close #3603. | ||||
* | c-user: Update type deprecation | Sebastian Huber | 2018-11-16 | 1 | -10/+5 |
| | | | | | | Update #3584. Update #3587. Update #3589. | ||||
* | c-user: Use common wording for build config opts | Sebastian Huber | 2018-11-05 | 2 | -7/+7 |
* | c-user: Update POSIX API configuration | Sebastian Huber | 2018-11-05 | 1 | -11/+22 |
| | | | | Close ##2514. | ||||
* | Document CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS | Sebastian Huber | 2018-10-30 | 1 | -0/+32 |
* | c-user/message_manager.rst: Change "cons void" to "const void" | Joel Sherrill | 2018-10-29 | 1 | -1/+1 |
| | | | | Closes #3575. | ||||
* | c-user: Clarify scheduler configuration | Sebastian Huber | 2018-10-26 | 3 | -23/+71 |
* | c-user: Modify CONFIGURE_INTERRUPT_STACK_SIZE | Sebastian Huber | 2018-10-22 | 1 | -12/+29 |
| | | | | | | | | | Use CPU_STACK_MINIMUM_SIZE instead of CONFIGURE_MINIMUM_TASK_STACK_SIZE to set the default value. Clarify documentation. Update #3480. | ||||
* | Update the copyright year. | Chris Johns | 2018-10-19 | 1 | -1/+1 |
* | c-user/index.rst: Reorder linker sets and directive status codes | Joel Sherrill | 2018-10-11 | 1 | -1/+1 |
* | barrier_manager.rst: Fix Barrier Wait Section Title | Joel Sherrill | 2018-10-05 | 1 | -2/+2 |
| | | | | closes #3538. | ||||
* | c-user: Document rtems_task_exit() | Sebastian Huber | 2018-10-04 | 1 | -1/+46 |
| | | | | Close #3533. | ||||
* | Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE | Sebastian Huber | 2018-09-17 | 1 | -26/+7 |
| | | | | | Close #3489. Close #3490. | ||||
* | c-user: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE | Sebastian Huber | 2018-09-17 | 1 | -33/+7 |
| | | | | Close #3488. | ||||
* | c-user: Mention thread pinning | Sebastian Huber | 2018-09-10 | 1 | -0/+22 |
| | | | | Close #3508. | ||||
* | c-user: Mention per-processor data | Sebastian Huber | 2018-09-10 | 1 | -0/+18 |
| | | | | Close #3507. | ||||
* | build: Fix indexing so it works on HTML and PDF. | Chris Johns | 2018-08-21 | 2 | -5/+1 |
| | | | | | | | | | | | | - Remove all genindex.rst files, these are generated and should not exist in our source. - Fix the HTML templates so the local specialisation works. - Add a index link to the sidebar for HTML. Note, there is no TOC entry for the index in the PDF output and I cannot figure out how to add one. Closes #3503 | ||||
* | c-user: SMP is supported on RISC-V | Sebastian Huber | 2018-08-11 | 1 | -1/+3 |
| | | | | Update #3433. | ||||
* | c-user: Adjust integer types in partition create | Sebastian Huber | 2018-08-10 | 1 | -2/+2 |
| | | | | Close #3486. | ||||
* | c-user: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE | Sebastian Huber | 2018-08-07 | 1 | -7/+37 |
| | | | | Close #3434. | ||||
* | c-user: Sort POSIX configuration options | Sebastian Huber | 2018-08-07 | 1 | -60/+60 |
* | c-user: Update partition create documentation | Sebastian Huber | 2018-08-03 | 1 | -11/+54 |
| | | | | | | Add an example. Close #3482. | ||||
* | c-user: Document RTEMS_SYSINIT_CPU_COUNTER | Sebastian Huber | 2018-06-19 | 1 | -0/+6 |
| | | | | Update #3456. | ||||
* | c-user: Remove obsolete RTEMS_SYSINIT_CPU_SET | Sebastian Huber | 2018-06-18 | 1 | -4/+0 |
| | | | | Update #2514. | ||||
* | c-user: RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE | Sebastian Huber | 2018-06-05 | 1 | -0/+4 |
| | | | | Close #3437. | ||||
* | c-user: Update rtems_region_create() | Sebastian Huber | 2018-06-05 | 1 | -9/+10 |
* | configuring_a_system.rst, scheduling_concepts.rst: Fix spelling of arbitrary. | Joel Sherrill | 2018-05-23 | 2 | -2/+2 |
* | c-user: changed RTEMS_STATUS_SUCCESSFUL to RTEMS_SUCCESSFUL | Malte Münch | 2018-05-20 | 1 | -2/+2 |
* | c-user/configuring_a_system.rst: Removed double 'with' | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | fix typo: extesion->extension | Malte Münch | 2018-05-18 | 1 | -1/+1 |
* | c-user: Update manual organization in overview | Malte Münch | 2018-05-18 | 1 | -32/+57 |
* | c-user: Fix reference | Sebastian Huber | 2018-04-30 | 1 | -6/+6 |
* | c-user: Fix typo | Sebastian Huber | 2018-04-30 | 1 | -2/+2 |
* | c-user: Properly fix the previous typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Fix typo | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
* | c-user: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 1 | -45/+54 |
| | | | | Close #3325. | ||||
* | c-user: Fix simple SMP scheduler limits | Sebastian Huber | 2018-03-09 | 1 | -1/+1 |
* | c-user: Rework scheduler alogrithm config defs | Sebastian Huber | 2018-03-08 | 1 | -78/+92 |
| | | | | Update #3325. | ||||
* | c-user: Rework clustered scheduling configuration | Sebastian Huber | 2018-03-07 | 2 | -151/+185 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 7 | -25/+25 |
* | c-user: Sort scheduler configuration options | Sebastian Huber | 2018-03-07 | 1 | -96/+96 |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 3 | -8/+7 |
| | | | | Add own section for the clustered scheduler configuration. | ||||
* | c-user: Fix scheduler configuration overview | Sebastian Huber | 2018-03-07 | 2 | -4/+6 |
* | c-user: Update CONFIGURE_SCHEDULER_NAME | Sebastian Huber | 2018-03-07 | 2 | -9/+27 |
* | CONFIGURE_*_SIMPLE_TASK_CONSOLE_DRIVER | Sebastian Huber | 2018-03-06 | 1 | -13/+84 |
| | | | | Update #3320. |
