* | c-user: Fix interrupt lock documentation | Sebastian Huber | 2017-07-14 | 1 | -19/+37 |
| | | | | Close #3075. | ||||
* | Use a single top level version number. | Chris Johns | 2017-03-20 | 1 | -6/+5 |
| | | | | | | | Fix the path in the catalogue links to allow prefix testing on a local disk. Close #2940. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 38 | -57/+55 |
* | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 2016-11-08 | 2 | -4/+5 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 30 | -8135/+7796 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 7 | -109/+28 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 41 | -0/+24958 |
