2023-05-20 | Update company name | Sebastian Huber | 3 | -3/+3 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-05-09 | c-user: Generate API type documentation | Sebastian Huber | 1 | -6/+6 | |
Close #4901. | |||||
2022-11-30 | c-user/*: Add trailing parentheses on methods in index which were missing it | Joel Sherrill | 1 | -1/+1 | |
Closes #4766. | |||||
2021-09-15 | c-user: Clarify rtems_extension_create() | Sebastian Huber | 1 | -3/+7 | |
2021-06-15 | c-user: Use a common phrase for pointer parameters | Sebastian Huber | 1 | -4/+4 | |
Mention the type of the pointer in the parameter description. Use the more general term "object" instead of "variable". Update #3993. | |||||
2021-04-21 | c-user: Add user extensions glossary terms | Sebastian Huber | 1 | -9/+4 | |
2021-02-10 | c-user: Generate user extensions manager docs | Sebastian Huber | 2 | -111/+255 | |
The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | |||||
2021-02-10 | c-user: Add labels to the manager chapters | Sebastian Huber | 1 | -1/+1 | |
2020-09-02 | c-user: Split up user extensions manager | Sebastian Huber | 4 | -0/+588 | |
This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. |
