2022-11-30 | c-user/*: Add trailing parentheses on methods in index which were missing it | Joel Sherrill | 1 | -1/+1 | |
Closes #4766. | |||||
2021-04-21 | c-user: Add user extensions glossary terms | Sebastian Huber | 1 | -9/+4 | |
2020-09-02 | c-user: Split up user extensions manager | Sebastian Huber | 1 | -161/+0 | |
This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | |||||
2020-06-18 | c-user: Mention possible preemptions | Sebastian Huber | 1 | -3/+4 | |
Mention that object create/delete may case the calling task to be preempted due to the object allocator mutex. | |||||
2020-04-17 | c-user: Document rtems_extension_create() | Sebastian Huber | 1 | -0/+2 | |
Close #3953. | |||||
2020-03-03 | c-user: Document thread switch extension changes | Sebastian Huber | 1 | -13/+27 | |
Close #3885. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2018-01-05 | c-user: Clarify user extensions | Sebastian Huber | 1 | -10/+16 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -4/+8 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -30/+31 | |
2017-08-24 | c-user: Clarify user extensions | Sebastian Huber | 1 | -59/+66 | |
Close #2367. | |||||
2017-01-26 | c-user: Rework user extensions chapter | Sebastian Huber | 1 | -301/+281 | |
Update #2692. Update #2752. | |||||
2016-12-12 | Improve fatal error chapter | Sebastian Huber | 1 | -1/+1 | |
Update #2825. | |||||
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -79/+76 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | c_user: Remove errors and warnings. | Chris Johns | 1 | -0/+2 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -13/+13 | |
2016-05-02 | Clean ups. | Chris Johns | 1 | -335/+302 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -14/+14 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -68/+71 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+589 | |
