path: root/c-user/timespec_helpers.rst (follow)
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-1/+1
* Clean up sphinx warnings.Chris Johns2017-11-131-14/+28
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* c-user: Fix index locations.Chris Johns2017-11-121-15/+17
| | | | Update #3229.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-1/+1
* c-user: Format the directives as descriptions.Chris Johns2016-11-081-244/+234
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+548
