2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -244/+234 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Fix double quotes. | Chris Johns | 1 | -4/+4 | |
2016-05-02 | Clean up. | Chris Johns | 1 | -163/+206 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -4/+4 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -14/+112 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+405 | |
