* | c-user: Document task memory | Sebastian Huber | 2020-03-05 | 1 | -12/+52 |
| | | | | Close #3835. | ||||
* | Address several issues from compiling examples | Martin Erik Werner | 2019-09-03 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Compiling the code from examples "code-block:: c" along with public includes and a bsp exposed a few issues amongst a lot of false positives. Address some of these: * Terminate struct declarations with ';'. Mainly for pedantic correctness. * Show ptrdiff_t instead of size_t for the sbrk() prototype, matching the current argument type in rtems. * Replace some occurrences of unsigned16 with uint16_t. * Fix odd type declaration, "uint8_t char*" -> "char*". * Use appropriate helper to get chain head instead of invalid access to nonexistent struct member. * Remove several excess '\' escapes. * Use RTEMS_SELF instead of undefined SELF. * Use rtems_task instead of void for task functions. * Add missing stack size parameter in task creation. * Use rtems_interrupt_level instead of undefined rtems_interrupt. * Correct return value format for rtems_object_id_get_api() rtems_object_id_get_index() (enum and uint16_t) and also fix corresponding print formatting. * Correct return value documentation for rtems_object_id_get_class(), rtems_object_id_get_node() and rtems_object_id_get_index() int -> uint32_t. * Use RTEMS_SUCCESSFUL instead of undefined RTEMS_STATUS_SUCCESSFUL and fix return value variable name in rate monotonic examples. * Use RTEMS_TIMEOUT instead of undefined TIMEOUT and RTEMS_PERIOD_STATUS instead of undefined STATUS. * Add missing fields to ftpd configuration. * Correct parameter types in ftpd hook prototype, unsigned char * -> void *. * Fix various code-block:: attributes, c -> makefile and c -> shell. * Add missing parenthesis in socket buffer memory calculation example. * Remove typedef in declaration of mq_attr since it is defiend without typedef in reality. * Update siginfo_t declaration to match current reality. * Update shell user command definition example to include mode, uid and gid. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Document rtems_task_exit() | Sebastian Huber | 2018-10-04 | 1 | -1/+46 |
| | | | | Close #3533. | ||||
* | Account for non-preemption and interrupt level not supported on SMP | Joel Sherrill | 2017-12-06 | 1 | -0/+8 |
| | | | | Closes #3000. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -21/+42 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -69/+78 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -7/+7 |
| | | | | Update #3220. | ||||
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 |
* | c-user: Update scheduler/task chapter | Sebastian Huber | 2017-07-10 | 1 | -1/+6 |
| | | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063. | ||||
* | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 2017-03-08 | 1 | -1/+3 |
* | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 2017-03-07 | 1 | -31/+39 |
* | c-user: Move some task directives | Sebastian Huber | 2017-02-01 | 1 | -0/+234 |
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 1 | -0/+14 |
| | | | | Update #2858. | ||||
* | c-user: Fix typo | Sebastian Huber | 2017-01-17 | 1 | -1/+1 |
* | Document rtems_task_get_priority() | Sebastian Huber | 2016-12-19 | 1 | -0/+51 |
| | | | | Close #2784. | ||||
* | Update Task Manager chapter | Sebastian Huber | 2016-12-13 | 1 | -184/+180 |
| | | | | | | Introduce "Deprecated and Removed Directives" section. Update #2423. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -789/+782 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+1650 |
