* | Account for non-preemption and interrupt level not supported on SMP | Joel Sherrill | 2017-12-06 | 1 | -0/+8 |
| | | | | Closes #3000. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -21/+42 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -69/+78 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -7/+7 |
| | | | | Update #3220. | ||||
* | c-user: Fix task create notes | Sebastian Huber | 2017-09-14 | 1 | -2/+6 |
* | c-user: Update scheduler/task chapter | Sebastian Huber | 2017-07-10 | 1 | -1/+6 |
| | | | | | | | Reflect EDF SMP scheduler changes. Close #3059. Close #3063. | ||||
* | c-user: Add note to rtems_task_set_scheduler() | Sebastian Huber | 2017-03-08 | 1 | -1/+3 |
* | c-user: Update rtems_task_set_scheduler() | Sebastian Huber | 2017-03-07 | 1 | -31/+39 |
* | c-user: Move some task directives | Sebastian Huber | 2017-02-01 | 1 | -0/+234 |
* | c-user: Task names | Sebastian Huber | 2017-01-31 | 1 | -0/+14 |
| | | | | Update #2858. | ||||
* | c-user: Fix typo | Sebastian Huber | 2017-01-17 | 1 | -1/+1 |
* | Document rtems_task_get_priority() | Sebastian Huber | 2016-12-19 | 1 | -0/+51 |
| | | | | Close #2784. | ||||
* | Update Task Manager chapter | Sebastian Huber | 2016-12-13 | 1 | -184/+180 |
| | | | | | | Introduce "Deprecated and Removed Directives" section. Update #2423. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -789/+782 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Update due to clock manager and driver changes | Sebastian Huber | 2016-11-03 | 1 | -1/+1 |
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+1650 |
