2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-03-28 | c-user/smp: Fix item rendering | Kinsey Moore | 1 | -1/+1 | |
2022-05-20 | c-user: Update references to --enable-* configure options. | Joel Sherrill | 1 | -7/+16 | |
Also updated list of SMP architectures and added enough lead in to let users know the source code was the definitive answer. | |||||
2020-03-03 | c-user: Document thread switch extension changes | Sebastian Huber | 1 | -0/+2 | |
Close #3885. | |||||
2019-04-09 | c-user: rtems_scheduler_get_processor_maximum() | Sebastian Huber | 1 | -43/+0 | |
Close #3732. | |||||
2019-04-09 | c-user: Document rtems_scheduler_get_processor() | Sebastian Huber | 1 | -35/+0 | |
Close #3731. | |||||
2019-03-13 | c-user: Mention atomic operations API | Sebastian Huber | 1 | -0/+8 | |
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+2 | |
2018-11-05 | c-user: Use common wording for build config opts | Sebastian Huber | 1 | -2/+2 | |
2018-10-26 | c-user: Clarify scheduler configuration | Sebastian Huber | 1 | -0/+2 | |
2018-09-10 | c-user: Mention thread pinning | Sebastian Huber | 1 | -0/+22 | |
Close #3508. | |||||
2018-09-10 | c-user: Mention per-processor data | Sebastian Huber | 1 | -0/+18 | |
Close #3507. | |||||
2018-08-11 | c-user: SMP is supported on RISC-V | Sebastian Huber | 1 | -1/+3 | |
Update #3433. | |||||
2018-04-30 | c-user: Fix reference | Sebastian Huber | 1 | -6/+6 | |
2018-03-07 | c-user: Use uniprocessor throughout | Sebastian Huber | 1 | -12/+12 | |
2018-03-07 | c-user: Promote clustered scheduler configuration | Sebastian Huber | 1 | -2/+1 | |
Add own section for the clustered scheduler configuration. | |||||
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -3/+3 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -4/+9 | |
2017-11-09 | Change RTEMS version to 5 | Sebastian Huber | 1 | -2/+2 | |
Update #3220. | |||||
2017-09-14 | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 1 | -1/+4 | |
2017-05-11 | c-user: Replace pre-emption with preemption | Sebastian Huber | 1 | -6/+6 | |
2017-02-14 | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 1 | -3/+3 | |
Update #2894. | |||||
2017-02-03 | c-user: Add SMP internal locking | Sebastian Huber | 1 | -0/+38 | |
2017-02-03 | c-user: Add SMP profiling | Sebastian Huber | 1 | -0/+58 | |
2017-02-03 | c-user: Update SMP introduction | Sebastian Huber | 1 | -15/+46 | |
2017-02-03 | c-user: New SMP chapter title | Sebastian Huber | 1 | -2/+2 | |
2017-02-03 | c-user: Add TAS and TTAS terms | Sebastian Huber | 1 | -2/+2 | |
2017-02-03 | c-user: Update scheduler helping protocol | Sebastian Huber | 1 | -68/+50 | |
2017-02-02 | c-user: Add SMP low-level synchronization | Sebastian Huber | 1 | -41/+81 | |
2017-02-02 | c-user: Add SMP implementation details section | Sebastian Huber | 1 | -38/+41 | |
2017-02-02 | c-user: Add SMP application issues section | Sebastian Huber | 1 | -150/+191 | |
2017-02-02 | c-user: Update clustered scheduling | Sebastian Huber | 1 | -21/+45 | |
2017-02-01 | Use "in X config..." instead of "on X config..." | Sebastian Huber | 1 | -6/+6 | |
2017-02-01 | c-user: Move scheduler directives | Sebastian Huber | 1 | -166/+0 | |
2017-02-01 | c-user: Remove duplicate thread queue section | Sebastian Huber | 1 | -50/+0 | |
2017-02-01 | c-user: Update task migration | Sebastian Huber | 1 | -29/+9 | |
2017-02-01 | c-user: Move some task directives | Sebastian Huber | 1 | -237/+0 | |
2017-01-24 | c-user: SMP thread dispatching | Sebastian Huber | 1 | -57/+23 | |
Close #2809. | |||||
2017-01-18 | c-user: Add support for references via bibtex | Sebastian Huber | 1 | -9/+4 | |
https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | |||||
2016-11-10 | c-user: Document scheduler add/remove processor | Sebastian Huber | 1 | -16/+100 | |
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -2/+1 | |
2016-11-08 | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 1 | -2/+2 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -229/+230 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-10-28 | c_user: Remove errors and warnings. | Chris Johns | 1 | -13/+15 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Fix SMP warning. | Chris Johns | 1 | -1/+1 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -11/+10 | |
