* | c-user: rtems_scheduler_get_processor_maximum() | Sebastian Huber | 2019-04-09 | 1 | -43/+0 |
| | | | | Close #3732. | ||||
* | c-user: Document rtems_scheduler_get_processor() | Sebastian Huber | 2019-04-09 | 1 | -35/+0 |
| | | | | Close #3731. | ||||
* | c-user: Mention atomic operations API | Sebastian Huber | 2019-03-13 | 1 | -0/+8 |
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+2 |
* | c-user: Use common wording for build config opts | Sebastian Huber | 2018-11-05 | 1 | -2/+2 |
* | c-user: Clarify scheduler configuration | Sebastian Huber | 2018-10-26 | 1 | -0/+2 |
* | c-user: Mention thread pinning | Sebastian Huber | 2018-09-10 | 1 | -0/+22 |
| | | | | Close #3508. | ||||
* | c-user: Mention per-processor data | Sebastian Huber | 2018-09-10 | 1 | -0/+18 |
| | | | | Close #3507. | ||||
* | c-user: SMP is supported on RISC-V | Sebastian Huber | 2018-08-11 | 1 | -1/+3 |
| | | | | Update #3433. | ||||
* | c-user: Fix reference | Sebastian Huber | 2018-04-30 | 1 | -6/+6 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -12/+12 |
* | c-user: Promote clustered scheduler configuration | Sebastian Huber | 2018-03-07 | 1 | -2/+1 |
| | | | | Add own section for the clustered scheduler configuration. | ||||
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -3/+3 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -4/+9 |
* | Change RTEMS version to 5 | Sebastian Huber | 2017-11-09 | 1 | -2/+2 |
| | | | | Update #3220. | ||||
* | c-user: Clarify SMP's rtems_get_processor_count. | Chris Johns | 2017-09-14 | 1 | -1/+4 |
* | c-user: Replace pre-emption with preemption | Sebastian Huber | 2017-05-11 | 1 | -6/+6 |
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -3/+3 |
| | | | | Update #2894. | ||||
* | c-user: Add SMP internal locking | Sebastian Huber | 2017-02-03 | 1 | -0/+38 |
* | c-user: Add SMP profiling | Sebastian Huber | 2017-02-03 | 1 | -0/+58 |
* | c-user: Update SMP introduction | Sebastian Huber | 2017-02-03 | 1 | -15/+46 |
* | c-user: New SMP chapter title | Sebastian Huber | 2017-02-03 | 1 | -2/+2 |
* | c-user: Add TAS and TTAS terms | Sebastian Huber | 2017-02-03 | 1 | -2/+2 |
* | c-user: Update scheduler helping protocol | Sebastian Huber | 2017-02-03 | 1 | -68/+50 |
* | c-user: Add SMP low-level synchronization | Sebastian Huber | 2017-02-02 | 1 | -41/+81 |
* | c-user: Add SMP implementation details section | Sebastian Huber | 2017-02-02 | 1 | -38/+41 |
* | c-user: Add SMP application issues section | Sebastian Huber | 2017-02-02 | 1 | -150/+191 |
* | c-user: Update clustered scheduling | Sebastian Huber | 2017-02-02 | 1 | -21/+45 |
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -6/+6 |
* | c-user: Move scheduler directives | Sebastian Huber | 2017-02-01 | 1 | -166/+0 |
* | c-user: Remove duplicate thread queue section | Sebastian Huber | 2017-02-01 | 1 | -50/+0 |
* | c-user: Update task migration | Sebastian Huber | 2017-02-01 | 1 | -29/+9 |
* | c-user: Move some task directives | Sebastian Huber | 2017-02-01 | 1 | -237/+0 |
* | c-user: SMP thread dispatching | Sebastian Huber | 2017-01-24 | 1 | -57/+23 |
| | | | | Close #2809. | ||||
* | c-user: Add support for references via bibtex | Sebastian Huber | 2017-01-18 | 1 | -9/+4 |
| | | | | | | https://sphinxcontrib-bibtex.readthedocs.io/en/latest/index.html Update #2871. | ||||
* | c-user: Document scheduler add/remove processor | Sebastian Huber | 2016-11-10 | 1 | -16/+100 |
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -2/+1 |
* | c-user: Correct copyright attribution to match original texinfo files | Joel Sherrill | 2016-11-08 | 1 | -2/+2 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -229/+230 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+995 |
