* | c-user: CONFIGURE_MAXIMUM_MRSP_SEMAPHORES | Sebastian Huber | 2019-12-19 | 1 | -7/+12 |
| | | | | | | | Remove use of CONFIGURE_MAXIMUM_MRSP_SEMAPHORES in example. Fix other configuration options. Update #3833. | ||||
* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Use uniprocessor throughout | Sebastian Huber | 2018-03-07 | 1 | -1/+1 |
* | Mention barrier manager in rtems_semaphore_flush() | Sebastian Huber | 2017-11-20 | 1 | -0/+4 |
* | c-users: Clarify semaphore obtain/flush | Sebastian Huber | 2017-11-16 | 1 | -1/+43 |
* | Clean up sphinx warnings. | Chris Johns | 2017-11-13 | 1 | -7/+14 |
| | | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -22/+21 |
* | c-user: CONFIGURE_MAXIMUM_PROCESSORS | Sebastian Huber | 2017-02-14 | 1 | -1/+1 |
| | | | | Update #2894. | ||||
* | c-user: Eliminate CONFIGURE_SMP_APPLICATION | Sebastian Huber | 2017-02-03 | 1 | -1/+0 |
| | | | | Update #2893. | ||||
* | Use "in X config..." instead of "on X config..." | Sebastian Huber | 2017-02-01 | 1 | -5/+5 |
* | c-user: Add Key concept locking protocols | Sebastian Huber | 2017-02-01 | 1 | -85/+8 |
| | | | | | Update #2412. Update #2556. | ||||
* | c-user: Clarify simple binary semaphore release | Sebastian Huber | 2017-01-23 | 1 | -9/+11 |
| | | | | Close #2725. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -472/+472 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+978 |
