path: root/c-user/semaphore_manager.rst (follow)
* Simplify SPDX-License-Identifier commentSebastian Huber2019-01-111-1/+1
* Remove superfluous "All rights reserved."Sebastian Huber2019-01-111-1/+0
* Use standard format for copyright linesSebastian Huber2019-01-111-2/+1
* c-user: Use uniprocessor throughoutSebastian Huber2018-03-071-1/+1
* Mention barrier manager in rtems_semaphore_flush()Sebastian Huber2017-11-201-0/+4
* c-users: Clarify semaphore obtain/flushSebastian Huber2017-11-161-1/+43
* Clean up sphinx warnings.Chris Johns2017-11-131-7/+14
| | | | | | | | | | - Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229.
* c-user: Fix index locations.Chris Johns2017-11-121-22/+21
| | | | Update #3229.
* c-user: CONFIGURE_MAXIMUM_PROCESSORSSebastian Huber2017-02-141-1/+1
| | | | Update #2894.
* c-user: Eliminate CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-031-1/+0
| | | | Update #2893.
* Use "in X config..." instead of "on X config..."Sebastian Huber2017-02-011-5/+5
* c-user: Add Key concept locking protocolsSebastian Huber2017-02-011-85/+8
| | | | | Update #2412. Update #2556.
* c-user: Clarify simple binary semaphore releaseSebastian Huber2017-01-231-9/+11
| | | | Close #2725.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-1/+1
* c-user: Format the directives as descriptions.Chris Johns2016-11-081-472/+472
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+978
