path: root/c-user/semaphore_manager.rst (follow)
* c-user: CONFIGURE_MAXIMUM_PROCESSORSSebastian Huber2017-02-141-1/+1
| | | | Update #2894.
* c-user: Eliminate CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-031-1/+0
| | | | Update #2893.
* Use "in X config..." instead of "on X config..."Sebastian Huber2017-02-011-5/+5
* c-user: Add Key concept locking protocolsSebastian Huber2017-02-011-85/+8
| | | | | Update #2412. Update #2556.
* c-user: Clarify simple binary semaphore releaseSebastian Huber2017-01-231-9/+11
| | | | Close #2725.
* c-user: Fix header levels. Minor fixes.Chris Johns2016-11-091-1/+1
* c-user: Format the directives as descriptions.Chris Johns2016-11-081-472/+472
| | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals.
* Rename all manuals with an _ to have a -. It helps released naming of files.Chris Johns2016-11-031-0/+978
