* | Simplify SPDX-License-Identifier comment | Sebastian Huber | 2019-01-11 | 1 | -1/+1 |
* | Remove superfluous "All rights reserved." | Sebastian Huber | 2019-01-11 | 1 | -1/+0 |
* | Use standard format for copyright lines | Sebastian Huber | 2019-01-11 | 1 | -2/+1 |
* | c-user: Fix typos | Frédéric Jouault | 2019-01-04 | 1 | -2/+2 |
| | | | | Close #3261. | ||||
* | c-user: Update type deprecation | Sebastian Huber | 2018-11-16 | 1 | -10/+5 |
| | | | | | | Update #3584. Update #3587. Update #3589. | ||||
* | c-user: Fix index locations. | Chris Johns | 2017-11-12 | 1 | -0/+3 |
| | | | | Update #3229. | ||||
* | Update rtems_interrupt_frame description | Sebastian Huber | 2016-12-19 | 1 | -1/+2 |
| | | | | Close #2808. | ||||
* | c-user: Fix header levels. Minor fixes. | Chris Johns | 2016-11-09 | 1 | -1/+1 |
* | c-user: Format the directives as descriptions. | Chris Johns | 2016-11-08 | 1 | -1/+1 |
| | | | | | | | | This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | ||||
* | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 2016-11-03 | 1 | -0/+386 |
