2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2023-05-09 | c-user: Generate API type documentation | Sebastian Huber | 1 | -6/+6 | |
Close #4901. | |||||
2022-09-29 | c-user: Add type roles | Sebastian Huber | 1 | -6/+6 | |
2021-06-15 | c-user: Use a common phrase for pointer parameters | Sebastian Huber | 1 | -16/+16 | |
Mention the type of the pointer in the parameter description. Use the more general term "object" instead of "variable". Update #3993. | |||||
2021-04-28 | c-user: Generate region manager documentation | Sebastian Huber | 1 | -458/+813 | |
The documentation is a consolidation of the comments in Doxygen markup and the documentation sources in Sphinx markup. The documentation was transfered to interface specification items. The documentation source files were generated from the items by a script. Update #3993. | |||||
2020-09-02 | c-user: Split up region manager | Sebastian Huber | 1 | -213/+0 | |
This makes it easier to automatically generate parts of the manager documentation in the future. Update #3993. | |||||
2019-12-12 | region_manager.rst: Add docs for region get info and get free info | Joel Sherrill | 1 | -0/+104 | |
closes #3751. | |||||
2019-01-11 | Simplify SPDX-License-Identifier comment | Sebastian Huber | 1 | -1/+1 | |
2019-01-11 | Remove superfluous "All rights reserved." | Sebastian Huber | 1 | -1/+0 | |
2019-01-11 | Use standard format for copyright lines | Sebastian Huber | 1 | -2/+1 | |
2018-06-05 | c-user: Update rtems_region_create() | Sebastian Huber | 1 | -9/+10 | |
2017-11-13 | Clean up sphinx warnings. | Chris Johns | 1 | -8/+16 | |
- Fix minor formatting issues. - Fix reference the gloassary TLS using ':term:'. - Make sure nothing is between an anchor and the heading where ':ref:' references the anchor. This meant moving all the recently added '.. index::' entries. Update #3232. Update #3229. | |||||
2017-11-12 | c-user: Fix index locations. | Chris Johns | 1 | -22/+25 | |
2017-01-27 | c-user: Clarify rtems_heap_extend() | Sebastian Huber | 1 | -9/+11 | |
Update #1747. | |||||
2017-01-27 | c-user: Region directives use the allocator mutex | Sebastian Huber | 1 | -3/+12 | |
2017-01-27 | c-user: Fix region directive prototypes | Sebastian Huber | 1 | -26/+26 | |
2016-11-09 | c-user: Fix header levels. Minor fixes. | Chris Johns | 1 | -1/+1 | |
2016-11-08 | c-user: Format the directives as descriptions. | Chris Johns | 1 | -326/+320 | |
This change combined with the element list change in latex generates a much better looking PDF. Add a page break before each directive to like th previous versions of the manuals. | |||||
2016-11-03 | Rename all manuals with an _ to have a -. It helps released naming of files. | Chris Johns | 1 | -0/+0 | |
2016-05-20 | Set SPDX License Identifier in each source file. | Chris Johns | 1 | -0/+2 | |
2016-05-02 | Change code to code-block. | Chris Johns | 1 | -8/+8 | |
2016-05-02 | Clean ups. | Chris Johns | 1 | -316/+368 | |
2016-05-02 | Convert all Unicode to ASCII(128) | Amar Takhar | 1 | -10/+10 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -121/+129 | |
2016-05-02 | Split document into seperate files by section. | Amar Takhar | 1 | -0/+593 | |
